duty/bar AVCR user's help! Adjusting question
Im runing 17psi daily. I personally keep my avcr set at 1.15 bar and duty at 50% all across the board (at track i turn it down to 45% to prevent over boosting). I know 17psi on the avcr is around 1.24/1.26bar or whatever they call it.
QUESTION TO ALL USERS:
So I run 17psi, you've all read that now: Should/Would it be better to say set the boost/bar higher at like 1.20 or 1.25 rather then 1.15 but at the same time lower the duty from my current 50% to I dunno say 25-35%. Im just wondering if any of you have spent some good time with this to try different combos. Its easy enough for me to do on my own but im curious as either way I will get my desired boost (17psi) but one will be forced by a higher duty and overshooting while the other is just setting the bar/boost at what I want my avcr to hit?
Any help is greatly appreciated! Thanks.
Hoosier Daddy
Sep 11, 2003 07:36 PM
