Quick wastegate question
Old Jul 2, 2004 | 12:28 AM
silver_nteg's Avatar
Default Quick wastegate question
hey all,
I was just wonder about tial wastegates. I see a 38mm with a .5 bar or a 40mm with a .8 bar. Which is right for my setup? what does the whole bar thing mean? I plan on having either a T3/t4 with a .57 trim and a .63 a/r, a SC61 or an SC34. This is going to be run on a 00 integra LS. thanks for your time
Old Jul 2, 2004 | 01:39 AM
pngfolife's Avatar
Default Re: Quick wastegate question (silver_nteg)
Get the 38mm since you probably won't be running lots and lots of boost. The 40mm would probably be overkill. Is you motor built and how much boost do you plan of running? Do you have a boost controller?
Old Jul 2, 2004 | 07:22 AM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver_nteg &raquo;</TD></TR><TR><TD CLASS="quote">what does the whole bar thing mean</TD></TR></TABLE>
bar thing is the amount of boost the wg will let you run at before having to use a boost controller.
1 bar is 14.7x its.73 or 75 i cant remember but thats close enough.
Sketch_hs
Aug 5, 2004 10:10 PM
LilManSi
Oct 18, 2003 06:37 AM
austrian type-R
Mar 18, 2003 12:15 PM
austrian type-R
Mar 6, 2003 10:37 AM
Type-ARR
Sep 23, 2001 10:38 PM
