Airflow/boost/power limitations on f23 head
Old Oct 7, 2003 | 04:13 PM
2ndae86's Avatar
Default Airflow/boost/power limitations on f23 head
I have a 98 accord with Fmax turbo. The motor is built(rods,pistons,sleeved,valve springs and retainers,no head work. At 11psi it makes 278hp/282tq. When I turn up boost to 16 psi it made 319hp/315tq. I was expecting more than that at 16psi. When running 7psi it made 233hp/235tq. I am using AEM EMS. The AFR's are great. Timing is still conservative. Iam assuming that the stock head just can't flow that much. Any ideas? If I have to run N2O to get the numbers I want I will, but I would rather not.
Old Oct 7, 2003 | 04:16 PM
IloveNewt's Avatar
Default Re: Airflow/boost/power limitations on f23 head (2ndae86)
What turbo are u runnin? Refreash my memory, teh f23 is the SHOC version of h23? Fill me in.
Old Oct 7, 2003 | 06:07 PM
2ndae86's Avatar
Default Re: Airflow/boost/power limitations on f23 head (MordecaiPSI)
Yeh, it's a 2.3 sohc. turbo t3/t4 that should be able to sustain 20ish psi on this setup.
Old Oct 7, 2003 | 06:14 PM
IloveNewt's Avatar
the # of psi does not = the volume of air it is actually pushin.
c5stunna
Feb 10, 2008 10:23 PM
BauleyCivic
Jan 6, 2006 10:36 AM
genop
Jan 28, 2004 08:34 PM
Markaccord95
Jan 28, 2002 10:43 AM
