DC JDM 4-1 header on B16?
Old Oct 6, 2003 | 09:49 PM
HYREV2NR's Avatar
Default DC JDM 4-1 header on B16?
I'm about to help a friend do some work on his EG hatch. We're dropping a B16 in the car & he's gonna be all motor for a bit so, have any of you guys use the DC header with the larger 2.5" collector on this motor before? He's got the common bolt-ons now. CAI, cat-back & test pipe. About to get the ECU re-chipped also.
Old Oct 6, 2003 | 10:03 PM
Padawan's Avatar
Darth ModerVader
Default Re: DC JDM 4-1 header on B16? (HYREV2NR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR &raquo;</TD></TR><TR><TD CLASS="quote">have any of you guys use the DC header with the larger 2.5" collector on this motor before?</TD></TR></TABLE>
I have. What in particular would you like to know?
Old Oct 6, 2003 | 10:15 PM
HYREV2NR's Avatar
Is it an improvement over a header with a smaller collector? I have an R & I went from a USDM DC 4-1 with stock cat to a JDM DC4-1 with a fat cat. Great bit of difference. Just wondered if it would cause the B16 to loose to much low end tq.
Old Oct 7, 2003 | 07:34 AM
Padawan's Avatar
Darth ModerVader
Default Re: (HYREV2NR)
It performed well on my application, which was an otherwise stock B16. There definitely wasn't a loss of low-end power.
Old Oct 7, 2003 | 07:39 AM
advanracing62's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">It performed well on my application, which was an otherwise stock B16. There definitely wasn't a loss of low-end power. </TD></TR></TABLE>
what header were you using before? I had a JDM 4-1 and it sucked on the B16- not enough low/mid power. I noticed a huge difference going to a JUN header, which still retained the 2.5" collector.
Old Oct 7, 2003 | 08:07 AM
Padawan's Avatar
Darth ModerVader
Default Re: (advanracing62)
It was previously the stock manifold. I never said it was exceptional (in fact, it was just on the car temporarily until it's final home came back from Florida), but it didn't lose low-end power. I can't imagine there being the huge difference that you describe between the DC and JUN (perhaps a few HP at various points on the curve), and I'd be interested in seeing some back-to-back dynos. What was your setup?
Edit: I don't mean this in an sarcastic way, but the butt-dyno is often wrong, and it's accuracy can be thrown off even more when an expensive part has just been installed in place of a cheaper one.
Old Oct 7, 2003 | 09:27 AM
Kidloco51's Avatar
Made decent power on my Si-B-16.
badasshatchhh
May 2, 2005 01:45 PM
pezzy
Jul 5, 2004 11:11 PM
GRAVEDIGGER
11
Aug 23, 2003 12:03 PM
95cx
Mar 9, 2003 06:43 PM
TedR719
Feb 17, 2003 04:58 PM
