Nitrous Oxide For Integra
I ordered a zex kit and civic type r camshafts for my 95 gsr still in process. I was wondering what's the maximum psi shots my motor can take? What do I need to make it take a big enough shot? maybe 75 or more? i heard that 65 is average. can someone help me or give me info on what to do thanks
If you must run 75...you def need 2 step colder plugs and you need to retard the timing. I wouldnt go over 75 on a dry kit...when youre getting that high you might want to consider a direct port setup and more extensive fuel and ignition modifications.
Stick with 65.
Stick with 65.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by player2z »</TD></TR><TR><TD CLASS="quote"> I was wondering what's the maximum psi shots my motor can take? </TD></TR></TABLE>
shots are not measured in PSI. psi refers to bottle pressure. When someone says a 65 shot that means a shot worth producing around 65 horsepower ..not 65 psi as you might have been thinking.
I would stay at 65, especially if its dry, which i beleive it is. Redlinegsr has been runnign the zex kit with no probs for about a year now, and pulling soem respectable times.
I don't mean to sound like a *****, but all of these people aren't really giving you good advice. I'm guessing you don't have the kit yet, b/c the instructions give the best advice.
Both my friend and I have run the zex kit on a B18C1 with no problems. A 55 shot is normal, without colder spark plugs or retarding timing. To run a 65 you need colder plugs and retard the timing -2. To run a 75 you need colder plugs and retard the timing -4 degrees.
Yes, people do run 100 shots on stock motors....but not for long. If you want to run anything over 75 shot you are going to want at least new rods/rings/pistons. Also, if you run over 75 you probably want a direct port nitrous system, as that will ensure you get the right amount of shot to each cylinder.
Please search and follow the instructions.
I just told him what Id do...Id be nervous shooting even a 55 shot without retarding the timing a degree and putting in at least one step colder plugs. Ugh Im a worrier though
whats the best bottle pressure to be running for a 75 shot at night........my friend had his 50 shot bottle pressure at 1300 he said it pulled hard i squeeze his car when it was at 950 felt barely nothing my skunk stage 2 feel stronger.........
I'm running b18b1. 440cc at 55 psiWet fogger kit 80 hp shot in now and a 100 also on stand by depending how it does -8 pulled for timing for 3rd and 4th gear
what step plugs should I run one or two step colder please from someone who has experience or a kit in there car thank u guys n girls
