engine swap questions
Old Oct 5, 2003 | 10:20 AM
faultofhumanity's Avatar
Default engine swap questions
alright had had this under a diff name(curiosity) but realized how horrible that was. so here :
i am beginning to save for my engine swap... it will be quite a while with my job but i should be able to afford it in spring next year depending on what i want. I want to have a good turbo platform and (correct me if i'm wrong) aren't sohc the better platforms? i've got a 95 civic dx coupe. i would like some input on what would be a good engine with a decent swap price, and very turbo compatible. i am looking for something under or around 1,500 but if forced to will go up to 2,000. i am hoping this might include a new and better tranny but if i have to save seperate then so be it. input on a good tranny for wanted setup would also be appreciated. thanx
Old Oct 5, 2003 | 10:23 AM
Default Re: engine swap questions (faultofhumanity)
bump to top
Old Oct 5, 2003 | 10:27 AM
KEVlN's Avatar
New User
Here check out these sites.
http://www.turbod16.com/
http://www.homemadeturbo.com
And here is some stuff I found using the search. Just type in "junkyard turbo" or "d16 turbo"
https://honda-tech.com/zerothread?id=633512
https://honda-tech.com/zerothread?id=520599
-Hope this helps. You can probably get a d16y8, the junkyard turbo, and still have money for tuning with a 2000$ budget.
Old Oct 5, 2003 | 11:12 AM
Default Re: engine swap questions (KEVlN)
ok.. so the d16y8 is a good turbo platform? what woulb be a good sturdy little tranny to go with it? i've got the dx but it has had a lot of grinding when my clutch fluid needed bleedin and i am not good at powershifting, not to mention i learned to drive a stick on this car. as this would be my first turbo setup, is there a decent kit that will come with decent parts that isn't too expensive? wanting to spend 2000 is just cause i want to be able to start this project in the early spring and that is what i project to have, if i have to i can save longer. i can wlays get motor swapped in and keep saving for the turbo kit. what kind of tuning will be needed to be done to this motor.
theblacksmith
Apr 8, 2017 10:08 AM
c2i0v0i0c
10
Dec 19, 2004 03:45 PM
hopsta
Aug 23, 2004 12:09 PM
faultofhumanity
Oct 5, 2003 10:25 AM
GSRwBOOST
Sep 6, 2002 06:13 PM
