stipped brake (hard) lines nuts?
Old Oct 4, 2003 | 04:48 PM
spencedogg's Avatar
Default stipped brake (hard) lines nuts?
I used a brand new craftsman flare nut wrench and stripped pretty much all the lines on the por valve what to do NOW???
Old Oct 4, 2003 | 04:53 PM
2lua's Avatar
you might need a flaring tool to reflare all the brake lines. unless you can put it back with a visegrip and the lines are not leaking then you be ok. if you using the flaring tool remember that the end of the brake lines are double flare.
Old Oct 4, 2003 | 04:58 PM
spencedogg's Avatar
ok so how do i get new nuts for the ends after the reflare?
Old Oct 4, 2003 | 05:01 PM
NonovUrbizniz's Avatar
Loved
Default Re: stipped brake (hard) lines nuts? (spencedogg)
damn that sucks...
You have to either unflare the stock lines and slide on new nuts then re-flare them (probobly won't work as they almost always if not always don't "un-flare) too well making them too short to make it to whatever.)
Short of that you need to run ENTIRE new hardlines from the master to the prop... Boy I hope you didn't strip the ones going OUT of the prop to the brakes... cuz that can get UGLY.
Are you sure you used the right size flarenut wrench... Thats one thing I won't trust to craftsman... their tolerances are a little less strict as the better companies so for something as do or die as brake hardline nuts I like to use only expensive tools...
One suggestion I have though is to use some of those rounded wrenches (like facom) which grip on the flat of the nut/bolt instead of the edges...
here's a link if you don't understand what I'm talking about... Nevermind I can't seem to find any right now (I though facom had it on ALL their wrenches but apparently not.)
-O-\
O
-O-/
If that makes any sense... the round "O"'s grip the flat spots on the nut instead of the the corners of the wrench gripping the corners of the nut...
2lua's Avatar
you go to napa and get you new fitting and remember it fine thread and metric. take your old one with you'
Old Oct 4, 2003 | 05:17 PM
spencedogg's Avatar
thanks you guys think napa is open on sunday i need my car on monday?
Old Oct 4, 2003 | 05:23 PM
2lua's Avatar
good luck!
Old Oct 4, 2003 | 09:49 PM
spencedogg's Avatar
bump it up
Old Oct 4, 2003 | 10:10 PM
SOHC_MShue's Avatar
i had the same problem with removing my power steering...i bought a shitty flare head wrench and stripped the nut. I ended up having to use vise grips.
Old Oct 5, 2003 | 04:33 AM
spencedogg's Avatar
up
Nickb257
May 4, 2010 01:44 AM
Jake92eg
19
Apr 9, 2008 11:30 AM
Dan_the_MaN
Oct 13, 2005 08:42 PM
bryan01
Honda Motorcycles
21
Mar 24, 2005 07:26 PM
Nextelbuddy
27
Jan 9, 2004 10:49 PM
