installing my JRSC friday.. any tips?
I have used JRSC kit.
bought a MVM stepper pulley with belt.
an-r intake gasket
goin to use an ls fuel rail. b16a has regulator in wrong spot.
dsm 450cc injectors
v-afc hack
i know to use hondabond as a gasket between the supercharger and manifold.
also use loctie on the 4 bolts.
bkr7e plugs
pr3 ecu with boost chip. 1degree retard for 1lb boost. no fuel changes
any tips or tricks or parts it looks like i'm missing?
an-r intake gasket
dsm 450cc injectors
v-afc hack
bkr7e plugs
it sounds like you're doing a B16A in an EF, no? if so, heres my writeup: https://honda-tech.com/zerothread?id=510810 i dont know what mounts you're using but many things may be similar. i share a few tricks that i found that may save you time.
HTH
HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madeiniraq »</TD></TR><TR><TD CLASS="quote">v-afc hack...pr3 ecu with boost chip. 1degree retard for 1lb boost. </TD></TR></TABLE>
My only concern would be whether 1 degree/psi would be enough considering that the hack will cause timing advance.
yes.. b16 in an ef.
intake manifold gasket has recently been replaced after i took off my itr intake.. i'm sure that will come off easy.
i think 8-10 degrees retard will be plenty and probably too much.
find someone with small hands to get to those intake manifold bolts!
use 12 points sockets/wrenches as much as possible......otherwise u might strip one or 2 bols like i did cause they were over tightend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madeiniraq »</TD></TR><TR><TD CLASS="quote">nice writeup keebler65
what throttle cable were you using that you had to make the "L" bracket?
1990 integra throttle cable.
