Finally, a Blow-Off Valve.... but is it worth it?
Old Sep 28, 2003 | 06:46 AM
Atlas's Avatar
Default Finally, a Blow-Off Valve.... but is it worth it?
The title is deciving, because I know it's worth it to have it, but here's my story:
I have been running a trubocharged Honda Civic (GReddy Eclipse style turbo) since the beginning of August. It has run fine, but I couldn't buy a BOV because I had to pay back the debt to my dad.
So now I am able to buy one, but is there damage to the turbine or to the wastegate because of not having one? After I get a BOV, should I get a new turbine? Or am I just freaking out?
thanx ^_^
Old Sep 28, 2003 | 06:56 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: Finally, a Blow-Off Valve.... but is it worth it? (Atlas)
All i can tell you to do is check for shaft play. It might not have messed anything up since you havent been running it like that for too long. What psi are you running? If its anything below 6 psi you should be fine unless you boost in every gear no matter where youre going
Sean
Old Sep 28, 2003 | 06:59 AM
Atlas's Avatar
Default Re: Finally, a Blow-Off Valve.... but is it worth it? (sCeRaXn)
im boosting 6... and I only boost like once a day... maybe twice...
Old Sep 28, 2003 | 07:46 AM
R6Elmo's Avatar
Yeah, CHeck shaft play man. I would think not running a bov for a week could really damage something. Even when you are not boosting, your turbo is still creating some sort of pressure. a BOV doesn't have to make noise to be working.
Just check it out and good luck.
Old Sep 28, 2003 | 11:40 AM
xci_ed6's Avatar
Default Re: Finally, a Blow-Off Valve.... but is it worth it? (R6Elmo)
I bet everything is fine. Lots of stock cars run w/o BOVs with no problems. Put the BOV on!
-Dustin
Old Sep 28, 2003 | 11:44 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Finally, a Blow-Off Valve.... but is it worth it? (krustindumm)
grand nationals never had blow off valves, but being automatics, they never really needed one. but in the 3 years of racing mine, i got the turbo new after i purchased the car, running 26 psi with no b.o.v. i sold the car 20,000 miles after i bought it with no turbo problems. take it for what you will. if it isnt passing oil, making noise, or have shaft play, you are cool.
but having a car with a stick, i would most definately run one.
Modified by boostedcivicsir at 5:49 AM 9/29/2003
Old Sep 28, 2003 | 12:23 PM
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">I bet everything is fine. Lots of stock cars run w/o BOVs with no problems. Put the BOV on!
-Dustin</TD></TR></TABLE>
what he said!
Old Sep 28, 2003 | 01:05 PM
Atlas's Avatar
Default Re: Finally, a Blow-Off Valve.... but is it worth it? (falconGSR)
thanx a bunch
anton_
Jun 24, 2008 09:21 AM
swappedcx
Aug 13, 2007 04:24 PM
EJ1 wilcox
Feb 3, 2007 10:32 PM
PUREVIL
May 20, 2003 09:13 PM
MotorMatrix.com
Jan 10, 2003 09:52 AM
