z6 or y8 tranny ?'s
Old Sep 27, 2003 | 06:13 AM
egizzle8
Guest
Posts: n/a
Default z6 or y8 tranny ?'s
Right now I using the dx tranny i my EG6 since I just got the car about 2 weeks ago not sure which tranny to go with. The z6 tranny or y8 tranny or if there is anything better for a daily driver and autoXing and looking for a new clutch. The car has a y7 in it now and boosted as soon as I can get the oilpressure sensor off! Dang nabbit! Though it'll be around 8-9psi so should I get a stage 2 or 3 clutch? Thanks
Old Sep 27, 2003 | 06:23 AM
boostsohfast's Avatar
Default Re: z6 or y8 tranny ?'s (egizzle6)
They y8 has steel shift forks. The z6 has cast aluminum, weaker, shift forks.
Old Sep 27, 2003 | 06:35 AM
egizzle8
Guest
Posts: n/a
Default Re: z6 or y8 tranny ?'s (boostsohfast)
gearing about the same on those? y8 might may be the way being newer also and less mileage.
Old Sep 27, 2003 | 06:36 AM
BauleyCivic's Avatar
Risky Business
gearing is identical
Old Sep 27, 2003 | 06:46 AM
TheAutoboxer
Guest
Posts: n/a
Default Re: z6 or y8 tranny ?'s (BauleyCivic)
yea ghet a y8, newer. also i heard the housing is better for cooling
Old Sep 27, 2003 | 06:47 AM
egizzle8
Guest
Posts: n/a
Default Re: z6 or y8 tranny ?'s (menkio)
Y8 it is!
Old Sep 27, 2003 | 12:20 PM
Mista Bone's Avatar
D Tranny Guru
92-95 EX/Si has a 1.900 2nd gear
96-00 EX has a 1.909 2nd gear
Close enough not to matter.
Old Sep 27, 2003 | 01:13 PM
Archidictus's Avatar
Unceasing Measure
Default Re: z6 or y8 tranny ?'s (Mista Bone)
Both put you at the end of third gear at the end of the strip, I know that for a fact.
Old Sep 27, 2003 | 03:25 PM
Default Re: z6 or y8 tranny ?'s (Archidictus)
My 3rd tops out at @ 90 mph.
Old Sep 27, 2003 | 05:13 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostsohfast &raquo;</TD></TR><TR><TD CLASS="quote">My 3rd tops out at @ 90 mph.</TD></TR></TABLE>
Exactly. In a stock SI, that's all you need to scoot down the track .
Old Sep 27, 2003 | 07:41 PM
Mista Bone's Avatar
D Tranny Guru
try about 6000 rpm in 4th gear, all motor.
Old Sep 27, 2003 | 08:33 PM
Average Al's Avatar
well this a picture of f-bared z6 tanny
Old Sep 27, 2003 | 11:53 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: z6 or y8 tranny ?'s (Average Al)
need explaining there. The second pic shows nothing unusual other than main bearing stuck in outer case half.
Old Sep 28, 2003 | 12:15 AM
ERA's Avatar
ERA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Both put you at the end of third gear at the end of the strip, I know that for a fact.</TD></TR></TABLE>
Only if your car is slow.... Get an ET in the triple digits and you'll need 4th.... <U>I</U> Know That For A Fact....
Old Sep 28, 2003 | 09:52 AM
Unceasing Measure
Default Re: z6 or y8 tranny ?'s (delslo26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo26 &raquo;</TD></TR><TR><TD CLASS="quote">
Only if your car is slow.... Get an ET in the triple digits and you'll need 4th.... <U>I</U> Know That For A Fact....</TD></TR></TABLE>
My car is a stock EH3 with 250k on the odometer: of course it's slow.
97spooncivic
Feb 1, 2006 08:48 PM
H.A.R.T b16a1crx
11
Sep 11, 2004 09:01 AM
95civicSirCoupe
Jun 4, 2004 05:27 AM
ASHY-ELBOW
Nov 4, 2003 12:36 PM
spencedogg
Aug 10, 2003 05:59 AM
