can it be the gasket??
my prelude doesn't seem to make hp after 4k rpm . i check it today , the gasket is leaking bad( the one from the manifold to wastgate) can this be the prolem
i feel turbo spool up at around 3k rpm , car pulling hard then power drop after that
doh. i didnt even read that your gasket was leaking, thats the problem. you wont spool up to full boost because the leaking gasket is working like a wastegate set at a lower boost. so you will see a lower boost. thats why you'r not feeling the same power as you had before.
