Crankshaft Position Sensor?
Old Sep 21, 2003 | 07:21 PM
HarryB's Avatar
From: Where All Funky Things Come From...., Stankonia, USA
Default Crankshaft Position Sensor?
Where is it on a 92 Civic Si?
Old Sep 21, 2003 | 10:42 PM
deepgreengsr's Avatar
Default Re: Crankshaft Position Sensor? (E@SpeedAddictMS)
well on a bseries motor its on the lower timeing belt pulley. the one that is connected to the crank. The pulley has teeth on the outside and a little magnetic pickup is bolted to the oil pump. Im sure its on the same place on a d series.
Old Sep 22, 2003 | 06:17 AM
jlicrx's Avatar
Default Re: Crankshaft Position Sensor? (deepgreengsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deepgreengsr &raquo;</TD></TR><TR><TD CLASS="quote">well on a bseries motor its on the lower timeing belt pulley. the one that is connected to the crank. The pulley has teeth on the outside and a little magnetic pickup is bolted to the oil pump. Im sure its on the same place on a d series.</TD></TR></TABLE>
on D-series, it is in the distributor
Old Sep 22, 2003 | 12:39 PM
Default Re: Crankshaft Position Sensor? (jlicrx)
cool. now I know.
Old Sep 22, 2003 | 12:45 PM
iakona's Avatar
can you retrofit one of these to an H22?
Old Sep 22, 2003 | 09:11 PM
Mochanic's Avatar
actually the sensor thats on the front of the crank is a crank fluctuation sensor that tells the computer there is detonation on a particular cylinder... the actual crank sensor is inside the distributor.
slowestek
Feb 28, 2010 09:21 PM
Shaynepolevault
Jan 25, 2010 10:03 PM
chicows18
Jul 19, 2009 06:45 PM
j_torres707
Mar 28, 2007 08:48 PM
