Throwing code 4 crank position sensor
Old Apr 17, 2009 | 09:17 AM
Shaynepolevault's Avatar
Icon2 Throwing code 4 crank position sensor
I have a 2000 b18b1 ls, im throwing code 4 which is the crank position sensor, where is it located? Some say by the crank pully some people are telling me the distributor. I need to know. Is it easier just to replace the distributor? please let me know quick my car wont rev pass 3,500 rpm. thanks in advance.
Old Apr 17, 2009 | 09:22 AM
dump3deg6's Avatar
Default Re: Throwing code 4 crank position sensor
CPS is a bitch.
Usually they're by the crank pulley.
Older cars theyre in the distributor
Old Apr 17, 2009 | 09:26 AM
so since my car is a 2000 is it by the crank pulley and if so how do i get to it?
Old Apr 17, 2009 | 09:31 AM
dump3deg6's Avatar
I BELIEVE you have to remove the plastic housing around the pulley, which envolves taking off the pulley itself.
Old Apr 17, 2009 | 09:37 AM
Icon2 Re: Throwing code 4 crank position sensor
do you know where i can get a picture or a how to foe the sensor
Old Apr 17, 2009 | 09:38 AM
i need to see it, i dont know what im looking for
Old Apr 17, 2009 | 09:44 AM
dump3deg6's Avatar
here is where its located at.. Not a LS motor, but you get the point
Old Apr 17, 2009 | 09:57 AM
mouab18c1's Avatar
timing belt covers have to come off as well as crank pulley.
Old Apr 17, 2009 | 10:04 AM
do obd1 cars have the sensor that is by the timing belt that crank position sensor? because I have a 2000 ls b18b1 but it is a swap and im running it on an obd1 ecu. So could it be that my distributor is bad? because people have told me that the obd1 ecu will delete that sensor and its like it isn't there so its going to be my distributor. What distributors fit the obd2b b18b1?
Old Apr 17, 2009 | 10:18 AM
bump please somebody help me out! do not want to buy parts i dont need.
Old Apr 17, 2009 | 10:33 AM
redlinetuning's Avatar
It was confusing reading your messages, but I get this.
motor: 2000 LS B18B1
ECU: OBD1 P74?
Car: ?
Any OBD2B non-VTEC Bseries distributor will work.
Becuase you have an OBD1 ecu, it does not have a Crank Position Sensor input.
Old Apr 17, 2009 | 10:49 AM
my car is a civic 1999 ex, which is obd2b like the 2000 ls b18b1. im using the engine harness from the car. so the engine harness is from my d16y8.
Old Apr 17, 2009 | 01:09 PM
94EG8's Avatar
Seagull Management
Originally Posted by dump3deg6
CPS is a bitch.
Not quite.
All OBD1 and OBD2 engines have a CKP sensor in the distributor
USDM OBD2 engines have a CKF sensor on the oil pump in addition to the CKP sensor. The CKF sensor never replace the CKP sensor, it mearly suplemented it.
Old Apr 17, 2009 | 01:19 PM
jdm602's Avatar
i believe if you use a jumper harness to go to obd1 it wont throw a code if its not plugged in. at least that was my case. 00 gsr in 97 hatch modified stock harness then obd2a to obd1 using chipped p28.
Old Apr 18, 2009 | 10:59 PM
ok so i changed my ecu from a stock obd1 p74 to a chipped obd1 p06. I noticed that the check engine light still came on, but it always comes on in the morning and is in limp mode because of the cel code 4, but after i have driven it a few times and started it a few times, when i start it it starts normal and no cel, and everything works fine. but for some reason in the morning i will get the cel and usually for only half the day until its been running and started a few times, then it goes away. I have ordered a distributor already. but could their be something else wrong. once again its a 2000 ls b18b1 obd2b swap into a 1999 civic ex using the stock civic engine harness throwing code 4. help please
Old Apr 18, 2009 | 11:35 PM
jdm602's Avatar
unplug the ckp. it should get rid of the code if its on an obd1 ecu.
Old Apr 19, 2009 | 12:35 AM
racebum's Avatar
will a jdm LS ecu fix the problem? i know you can run a JDM ITR ecu to fix this if you have a USDM ITR since the JDM ecu ignores this as well as the second o2
Old Jan 25, 2010 | 04:12 PM
danny_pack's Avatar
New User
i have a 91 crx with a b18c1 an its on limp mode i have put 3 brand new distributors 3 ecus (p28 an p72) its throwin the cps code the cps isnt pluged up theres nothin to plug it up to i have the jumper harness's to the ecu an the distributor, plz email me at gangster_cracker00180@yahoo or myspace at myspace.com/dropanddestroyem sum1 plz help me out
Old Jan 25, 2010 | 10:03 PM
boostedteg1203's Avatar
Check out FF-Squad.com they show you how to fix this type of stuff.
johnnyk1726
Sep 8, 2013 04:09 AM
toyotaking88
May 13, 2011 03:35 AM
kndj30
Honda Civic (2001 - 2005)
Feb 11, 2010 03:58 AM
xwhitchx
May 27, 2009 05:55 PM
lude98SH
Dec 27, 2007 10:32 AM
