200 hp goal, here is my setup. Will this setup take me there?
Old Sep 21, 2003 | 03:24 PM
Sinner's Avatar
Default 200 hp goal, here is my setup. Will this setup take me there?
Setup
d15b (jdm vtec) stock block retard timing. same as a d16z6 ~ 125hp
TD04 turbo
DSM g1 intercooler and BOV.
hallman manual boost controller(just set to 7.5 psi)
Ford 310cc injectors + fields controller / afc hack
E-cut (not installled yet) I'm hoping this will help out alot.
Gauges: EGT / A/F / Boost
My goal is 200 hp, I was around 160 with 5 psi. no cutout. I think my stock 's/dx' exhaust and cat was killing me. I figure install the cutout before the cat and bump but the boost.
Let me know what you think.
Old Sep 21, 2003 | 03:42 PM
nevin's Avatar
you would be close if you got 450s and the cutout and tuned it to 10 psi.
Old Sep 21, 2003 | 07:54 PM
Sinner's Avatar
is 10 psi what it takes to get a sohc to 200hp?
Old Sep 21, 2003 | 08:09 PM
nigel's Avatar
usually 12 does it. 12 for sure... and who cares if you blow it up? thos motors are what 300 bucks?
Old Sep 21, 2003 | 08:12 PM
Sinner's Avatar
maybe I should be looking for 200hp at the fly wheel ;-)
Old Sep 22, 2003 | 07:24 AM
TravSi's Avatar
Default Re: (Sinner)
I made 205whp on 6psi....so dont say it cant be done
Old Sep 22, 2003 | 07:53 AM
civperc's Avatar
Default Re: 200 hp goal, here is my setup. Will this setup take me there? (Sinner)
I'd go Hondata if you're looking for 200whp out of that kinda set-up.
Old Sep 22, 2003 | 08:22 AM
TravSi's Avatar
Default Re: 200 hp goal, here is my setup. Will this setup take me there? (untensadude)
i wouldnt really say that matters....i did it with afc hack, 450's and dsm fuel pump, stock fpr
Old Sep 22, 2003 | 08:26 AM
TravSi's Avatar
Default Re: 200 hp goal, here is my setup. Will this setup take me there? (RexSiT3)
This is my dyno sheet
This under the hood
Modified by RexSiT3 at 5:48 PM 9/22/2003
Manny86
Sep 19, 2007 06:21 PM
Sinner
Aug 1, 2004 12:30 PM
quik sol
Mar 11, 2004 07:00 AM
DBallz
Jul 16, 2003 12:21 PM
BlackOutSi
Mar 1, 2002 04:35 PM
