how to?
Old Sep 21, 2003 | 02:33 AM
h2392si's Avatar
Default how to?
i was wondering how i can check out the codes my ecu is trowing. The check engine light came on after i degreased the engine really good. Now the check engie light came on and i want to know if its something serious. Thanks in advance, ed.
Old Sep 21, 2003 | 03:21 AM
Green94GSR's Avatar
Car, Engine? Usually a diagnostic plug above passenger kick panel. Do you have a service manual?
Old Sep 21, 2003 | 06:47 AM
couter.net's Avatar
Default Re: (Green94GSR)
go here http://www.c-speedracing.com/faq/06.php
do that!
Then go here http://www.hybridgarage.com/tech/codes.html
Old Sep 21, 2003 | 08:06 AM
slvrcivic97's Avatar
Default Re: (couter)
put a paperclip in the little blue plug near the ecu area (near passenger side right foot), turn key to 2 position, and read the codes: 1 long beep = 10, 1 short beep=1. After the code is done, there will be a long pause. If that is the only code, it will repeat it over and over, if there is a new code, it will do that one next. That is why you should wait until you see the first code repeated-so you know you checked them all. Then turn off the car and remove the paperclip.
I-4
Jun 5, 2007 03:29 AM
DeDonDeRosa
Oct 2, 2004 05:22 PM
type Gendy
Apr 21, 2003 04:48 PM
RacerXintegra2k
Aug 13, 2002 09:15 PM
Todd00
May 24, 2002 07:04 PM
