How far has anyone ever taken the FMU?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stinker504 »</TD></TR><TR><TD CLASS="quote">How much boost and HP has anyone ever run safely with a FMU setup?</TD></TR></TABLE>
InlienPro has used FMU up to about 25-26psi and this was 12:1 FMU according to Jinxproof 440cc injectors and APEX AFC. They have made 400-450 max I believe on this setup, some NOVA guys may know better than I would. InlinePro knows there ****.
i pulled 12.40 on fmu+240's in a full interior/acc 95 teg....nothin special, i was only hittin 9psi...the pressure would get past #1 o-ring under 10-11psi, so i kept it a 9. no dyno but i expect about 250/200ish
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin »</TD></TR><TR><TD CLASS="quote">If the FMU raises the fuel pressure per lb of boost, wouldnt that come to stock fp+312? I would imagine it just stops raising the fuel pressure after a certain amount of boost.</TD></TR></TABLE>
It will continue to raise the fuel pressure up to the fuel pump's limit. The stronger your pump, the more pressure you'll run.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evoeone »</TD></TR><TR><TD CLASS="quote">i know some VR6 turbo dudes running mid 11's, 18 psi, and like 220 psi at the fuel rail
**** that's so dangerous. What fuel pump?
</TD></TR></TABLE>**** that's so dangerous. What fuel pump?
I'd like to know what pump as well.
</TD></TR></TABLE>I'd like to know what pump as well.
