Question on rear coilover install
Old Sep 13, 2003 | 10:33 AM
no2unenolife's Avatar
Default Question on rear coilover install
the rear bolts to take out on the lca aren't budging, i'm using at least 200 psi and a 300 lb ft trqe impact gun.. they turn about a quarter then stops and no movement beyond that? do u know y? what can i do to remove them, thanks asap..
Old Sep 13, 2003 | 10:35 AM
Default Re: Question on rear coilover install (climaxpinoy)
i forgot but it's my 94 ls
Old Sep 13, 2003 | 03:59 PM
VTECorona's Avatar
Can you take a pic of the exact one? Also, try to soak the threads\nut with WD40 or some kind of penetrating spray.
Old Sep 13, 2003 | 04:06 PM
J-g-D-s-M-r's Avatar
WD-40 it. if it doesn't it might be stripping the threads. so don't put too much force on it.
Old Sep 13, 2003 | 05:18 PM
Dan GSR's Avatar
Default Re: Question on rear coilover install (lDarkCloudl)
HEAT
torch that sucka....
i've always found that a propane torch does wonders for stuck bolts
Old Sep 13, 2003 | 05:19 PM
Phoenix_ITR's Avatar
i've always just used a really big hammer. ::shrugs:: worked for me.
Old Sep 13, 2003 | 10:53 PM
SweetChin's Avatar
Default Re: Question on rear coilover install (delinquent)
well hopefully you dont have the same problem that i had on both my integras...the bolts had froze in the control arm bushings where i eventually broke the heads off the bolts where i then had to cut the control arms out and replace the bushings and get new bolts...
anyways just try the wd-40 and with the impact gun try goin back and forth tightening and loosing the bolt
Old Sep 14, 2003 | 09:29 AM
roydogg's Avatar
Default Re: Question on rear coilover install (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">HEAT
i've always found that a propane torch does wonders for stuck bolts</TD></TR></TABLE>
Not all the time
Old Sep 14, 2003 | 09:38 AM
andrew dc's Avatar
Default Re: Question on rear coilover install (roydogg)
i have never took an impact to my car. I always use a breaker bar and slowly crack the bolt loose. go to the store and buy some PB blaster, soak then attack slowy, you dont want that impact to break the head off the bolt, then you will really be SOL.
Old Sep 14, 2003 | 11:42 AM
Dan GSR's Avatar
Default Re: Question on rear coilover install (andrew ef)
well atcually slowly turning it usually breaks the head off
i've found that impact (quick continous blows) does a better job
Old Sep 14, 2003 | 02:57 PM
1hotintegra's Avatar
if it moves a quater turn and moves back chances are its the bushing.
Old Sep 19, 2003 | 03:59 AM
i was thinking it's my bushing too..because i see the bushing spin sligtly with the bolt. and i put a lot of pb blaster too..
brewerkz
Honda CR-V & Element
Jul 23, 2017 07:52 AM
cehcivic15
14
Jun 18, 2012 12:50 PM
usmarinedelta
Dec 27, 2006 08:52 PM
conesmasher
Mar 20, 2003 11:36 AM
wideb18hatch
Mar 11, 2003 04:03 PM
