Frozen Control Arm bolts
It's a typical honda kinda thing. But does anyone know how much? the rear lower control arm bolts are that freeze up??????
Re: Frozen Control Arm bolts (blacks2000)
How much the bolts are to replace in parts terms. Just looking for a price on the bolts themselves, no labor.
1 Post
Re: Frozen Control Arm bolts (snoballgsr)
is anyone out there I know that you guys have replace these before, it is notorious on hondas
Re: Frozen Control Arm bolts (Eva01)
Try some rust penetrant and a breaker bar. Hmmm, I think I will try and start an impact wrench movement here on h-t...it doesn't cost that much and is darn worth it.
Re: Frozen Control Arm bolts (Trac226)
you'll be spending a lot of money if the heads on the bolts bust off. i learned the hard way... you're either gonna have to get a shop to put in new bushings in the LCAs or get new LCAs all together.
Once you get air tools, you never go back !
My air wrench took off the dreaded crankshaft pully bolt in about .25 seconds once I took the socket extension off.
Scary
Re: Frozen Control Arm bolts (Scary1109)
THe heads broke off of mine. The bushings are like 28 bucks each and the bolts are like 7 I think. You'll need a shop to press them out unless you wanna do it the ghetto way like I did. Get a blow torch, and get it icy hot like some of the stunna around here. Then pound it out with a hammer.
Well, the bolt snapped on both mine. One we drilled out. It took 6 hours. The other one, I think i'm just going to give up on salvaging the old control arms and just buy new ones. I got a hook up on drilling them out but they said that it would normally cost like 200 dollars. Thats like the cost of some ssr control arms. Thats crazy.
speedpro92
12-22-2010 08:17 AM
