OPEN LOOP MODE?
Old Sep 11, 2003 | 11:44 AM
Iamhonda's Avatar
Default OPEN LOOP MODE?
Can the OPEN LOOP MODE (o2 sensor unplug) causing the slow injection to fuel injectors? And dose it have anything to do with idle at all?
Old Sep 11, 2003 | 11:47 AM
Greyout's Avatar
Default Re: OPEN LOOP MODE? (Iamhonda)
question #1 - what?
question #2 - yes
Old Sep 11, 2003 | 12:00 PM
Iamhonda's Avatar
Default Re: OPEN LOOP MODE? (Greyout)
OK im sorry if my question was'nt clear im gonna try again.Here the question. What would happen if my o2 sensor is unplug ? I know its gonna throw a code but , dose it has anything to do with fuel system?
Old Sep 11, 2003 | 12:12 PM
AzG35's Avatar
Your car will run richer in low throttle operation (closed loop). But if you are full throttle (open loop), there should not be a difference in performance.
Old Sep 11, 2003 | 12:18 PM
Eyewitness's Avatar
Default Re: OPEN LOOP MODE? (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">Your car will run richer in low throttle operation (closed loop). But if you are full throttle (open loop), there should not be a difference in performance. </TD></TR></TABLE>
Exactly.....being in open loop all the time will kill you mpg because the engine does not use the sensors for feedback to adjust fuel....only tps
Iamhonda's Avatar
My car will stay at 200 rpm( when crank ) and when i step on gas the rpm will move up slowly. Do you think its have something to do with that?
Old Sep 11, 2003 | 12:37 PM
Eyewitness's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iamhonda &raquo;</TD></TR><TR><TD CLASS="quote">My car will stay at 200 rpm( when crank ) and when i step on gas the rpm will move up slowly. Do you think its have something to do with that?</TD></TR></TABLE>
The car should still operate pretty well....my car is always in open-loop because of my mugen chipped p28....its runs great but gets horrible gas milage. Even around town its runs good....idles at about 800 but i dont use it as a daily driver. Bu the car does not rev any slower due to being so rich
Old Sep 11, 2003 | 06:10 PM
Iamhonda's Avatar
Default Re: OPEN LOOP MODE? (Eyewitness)
but im running on stock p75 though. Im just trying to figure it out why my car acting funny. If OPEN LOOP is not the cause what could it be? I know it got something to do with my fuel system. Anyone got an idea?
Old Sep 11, 2003 | 06:42 PM
Eyewitness's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iamhonda &raquo;</TD></TR><TR><TD CLASS="quote">but im running on stock p75 though. Im just trying to figure it out why my car acting funny. If OPEN LOOP is not the cause what could it be? I know it got something to do with my fuel system. Anyone got an idea?</TD></TR></TABLE>
Ok the problem is probably why your running in open loop....you shouldnt be. If your 02 sensor is unplugged or damaged,plug it in or fix it. If your throwing any other codes check those and fix the problem.
jmeyer99
24
Nov 10, 2006 03:51 PM
osaltyone
Sep 9, 2006 08:43 PM
pipes
May 5, 2005 10:09 PM
CrX-To-Tha-Max-v2.0
Nov 20, 2004 03:05 PM
plnoldrick
Jun 14, 2004 03:10 PM
