Need Uberdata help: running lean only 20% of time
Old May 4, 2005 | 09:59 AM
pipes's Avatar
Default Need Uberdata help: running lean only 20% of time
This just started hapening recently. I'm using uberdata and 450cc's. So when I'm driving, my lambda air/fuel guauge reads super lean in closed loop, then it will go to normal again when I step on it enough to activate open loop, then back to super lean after I ease up on throttle. This happens even when I deactivate open loop and run only in closed loop. I'm thinking bad O2 sensor, or maybe fuel settings in in Uberdata are too low to keep injectors open? Usually heppens when cruising in 5th at very low throttle. Anyone have similar problems? After a few minutes it will run fine again...
Thanks
Modified by pipes at 7:28 PM 5/4/2005
Old May 4, 2005 | 10:01 AM
falcongsr's Avatar
What is this crap?
Default Re: Need Uberdata help: running lean only 20% of time (pipes)
do you have open loop / closed loop backwards? open loop = WOT/boost
i havent been in FI for a while, is uberdata real popular now?
Old May 4, 2005 | 10:12 AM
93turbo16's Avatar
are you using a wideband? If not, it sounds like fuel cut to me.
Old May 4, 2005 | 10:28 AM
pipes's Avatar
Default Re: Need Uberdata help: running lean only 20% of time (falcongsr)
sorry yes, allow me to fix post...
To answer your question, I havent been online much but Uberdata seems to be getting big for engine management.
Old May 4, 2005 | 10:29 AM
pipes's Avatar
Default Re: (93turbo16)
yes the reading was from a wideband. It seems exactly like a fuel cut, but why....
Old May 4, 2005 | 02:12 PM
SOHC_MShue's Avatar
you can't disable open loop in uberdata
Old May 4, 2005 | 02:35 PM
dustin's Avatar
Turn off closed loop entirely.
Old May 5, 2005 | 03:27 PM
pipes's Avatar
Default Re: Need Uberdata help: running lean only 20% of time (dustin)
how would I do that?
Old May 5, 2005 | 04:25 PM
SOHC_MShue's Avatar
go under the miscellanious tab in uberdata and disable it.
Old May 5, 2005 | 04:52 PM
stealthmode62's Avatar
Default Re: Need Uberdata help: running lean only 20% of time (SOHC_MShue)
What A/F represents "super lean"?
Just wondering.
Old May 5, 2005 | 10:09 PM
pipes's Avatar
yeah I disabled O2 heater, I thought there was another way...
By super lean I meant I was in the 17's.
Max500
Engine Management and Tuning
12
Oct 16, 2011 09:12 AM
teg racer 877
Oct 25, 2009 06:12 PM
underpressure02
Sep 22, 2004 12:34 PM
7rrivera7
May 30, 2003 04:26 AM
raene
Jul 17, 2001 12:32 PM
