PROBLEM: H22A Turbo
Old Sep 10, 2003 | 10:31 PM
InfamousDX's Avatar
Default PROBLEM: H22A Turbo
Friends' car is running like ****. Prelude on an FMAX Turbo Kit. I'll give you just the details.
Loud hissing while accelerating
A/F gauge constantly RICH
Absolutely NO boost
Lost 1/4 tank of gas driving 20-25 miles highway
We stop and pop the hood... instantly smell of gas eminates. He just went home to grab the CEL code. Any thoughts? Thanks.
Old Sep 10, 2003 | 10:32 PM
GraphiteAccord's Avatar
Default Re: PROBLEM: H22A Turbo (InfamousCivic)
What fuel system?
What's his A/f ratio?
Sounds like a charge pipe is leaking.
Old Sep 10, 2003 | 10:51 PM
safe driver's Avatar
Default Re: PROBLEM: H22A Turbo (GraphiteAccord)
sounds like an injector(s) could be stuck open and spraying fuel. check the plugs after a hard run to see if there if it is wet or not.
Old Sep 10, 2003 | 11:15 PM
DynamicCK's Avatar
H22 ecu's do not like boost. Try using a different ecu
Old Sep 10, 2003 | 11:18 PM
Default Re: PROBLEM: H22A Turbo (DynamicCK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DynamicCK &raquo;</TD></TR><TR><TD CLASS="quote">H22 ecu's do not like boost. Try using a different ecu</TD></TR></TABLE>
umm... all honda ecu's don't like boost... and the fmax kit comes with 2 extra injectors and its own controller.
Old Sep 10, 2003 | 11:49 PM
InfamousDX's Avatar
Default Re: PROBLEM: H22A Turbo (safe driver)
I would have to check out that fuel system but I know he's using the FMAX Additional Injector System.
The charge pipe is what I was thinking too but he has a heatshield and it was too damn hot to check at the moment.
And the A/F was read through an autometer gauge, nothing like a widebang O2 or anything.
Thanks for the help guys. Will report in the morning.
Old Sep 11, 2003 | 03:50 AM
ekb18c's Avatar
sounds liek a charge pipe is off. and mf2
Old Sep 11, 2003 | 09:35 AM
InfamousDX's Avatar
Default Re: PROBLEM: H22A Turbo (ekb18c)
Yea I'm not a big fan of the MF2 either but he says it works great. Apparently not.
Old Sep 11, 2003 | 10:41 AM
Happyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InfamousCivic &raquo;</TD></TR><TR><TD CLASS="quote">I would have to check out that fuel system but I know he's using the FMAX Additional Injector System.
Thanks for the help guys. Will report in the morning.</TD></TR></TABLE>
Any A/F gauge like autometer etc is going to be inaccurate. The only good thing about them is when at WOT it'll sorta tell you if you're running rich or not.
Old Sep 11, 2003 | 02:32 PM
InfamousDX's Avatar
Default Re: PROBLEM: H22A Turbo (eh6turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh6turbo &raquo;</TD></TR><TR><TD CLASS="quote">
Any A/F gauge like autometer etc is going to be inaccurate. The only good thing about them is when at WOT it'll sorta tell you if you're running rich or not.</TD></TR></TABLE>
I know that's why I said it's nothing like a Wideband O2. Oh well it's something at least.
Old Sep 11, 2003 | 04:55 PM
EG6owner-T's Avatar
does the mf2 light up red when open?
check for vaccum leaks and if its properly connected...
just some thoughts cause I know for a fact those kits are POSs
did you install a 3 bar map sensor and missing link?
Old Sep 11, 2003 | 06:18 PM
scatuli's Avatar
Default Re: PROBLEM: H22A Turbo (EG6owner)
i didnt have that same problem and i didnt open my hood to see fuel squirting out of my injector. it turns out i broke a o ring putting in the new injectors and i didnt drive it like that for about 2-3 days...
i think you get the point
Old Sep 13, 2003 | 10:38 AM
InfamousDX's Avatar
Default Re: PROBLEM: H22A Turbo (scatuli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scatuli &raquo;</TD></TR><TR><TD CLASS="quote">i didnt have that same problem and i didnt open my hood to see fuel squirting out of my injector. it turns out i broke a o ring putting in the new injectors and i didnt drive it like that for about 2-3 days...
Well thankfully there was no fuel spitting out because we checked the injectors. Sh*t I am yet to talk to my friend about how the car's going.
Old Sep 13, 2003 | 10:54 AM
Park the car till you get real engine management and a wideband.
Old Sep 14, 2003 | 10:25 AM
InfamousDX's Avatar
Yea this kid likes to buy real nice parts for his setup while stinging on important parts. He doesn't even have a V-AFC, let alone real engine management. How is it supposed to be tuned?? Ah well, he's not really taking good care of it since he got his gixxer.
Old Sep 14, 2003 | 10:58 AM
Couto's Avatar
what is your exhaust ????? maybe problem there ??? and air/fuel ratio to.....
COUTO
Old Sep 16, 2003 | 09:16 AM
InfamousDX's Avatar
Default Re: (Couto)
HIS exhaust is Apex'i N1 2.5" and a 2.5" downpipe.
Hiii Im TYLER
Apr 29, 2007 11:17 PM
ragethemachine86
Jul 15, 2006 06:55 PM
turboH22Aakkord
Aug 29, 2005 06:49 AM
tegman85
14
Aug 26, 2005 11:16 AM
racingfan
Nov 21, 2004 09:46 PM
