stripped crank at flywheel bolt
Old Sep 10, 2003 | 02:11 PM
MisterB's Avatar
Default stripped crank at flywheel bolt
One of the flywheel bolts on my b16 is stripped due to the flywheel coming loose Just the first two threads of the crank. Should i retap it or just run a die down to clean it up? Anyone know the size of the flywheel bolts?
Old Sep 10, 2003 | 02:51 PM
poison's Avatar
Default Re: stripped crank at flywheel bolt (MisterB)
if it's only the first two threads, then I would re-tap it to the same thread pattern, shouldn't be too hard. if the BOLT is stripped then I would replace it with a new one.
Old Sep 10, 2003 | 10:01 PM
MisterB's Avatar
Default Re: stripped crank at flywheel bolt (poison)
a few of the bolts are messed up so i will replace those.
what size are the bolts or should i just take one down when i get the tap?
Old Sep 10, 2003 | 11:24 PM
Stripped Honda's Avatar
99-0104
i also agree with the above post just use a tap to trace the threads and try to torque the bolts if they have side to side play in them or you cant torque them to spec you will probally need a new crank
also replace the bolts that were the problem
eh2_Trav
Transmission & Drivetrain
Nov 4, 2016 08:47 AM
c0d0r
Mar 29, 2009 02:22 PM
LsTurbo91
Jul 21, 2005 05:41 PM
Muckman
Jul 13, 2004 07:31 PM
Specialk
May 21, 2003 02:14 PM
