TPS help
Old Sep 7, 2003 | 06:25 PM
Audi RS4's Avatar
Lover
Default TPS help
I got my engine in the car (B16A). started to hook everything up and realize that there is no TPS. i looked and my friends Type R to see where it is on his.ell it sits right ontop of the TB. i have 2 small hoses coming out of the TB where his TPS is. this is my first swap and i'm in a little trouble. does anyone have a picture of a B16A SiR II TB that i can see if i'm just missing it or something.everything was going good up to this point.
thanks
Old Sep 7, 2003 | 06:44 PM
PhatOptimo's Avatar
Default Re: TPS help (AK1200)
Look at the 2nd picture down. Its the sensor on the back of the TB (black). The one with the 3 wire plug connected to it.
http://www.geocities.com/phato....html
Old Sep 7, 2003 | 06:51 PM
Audi RS4's Avatar
Lover
Default Re: TPS help (Quantum_CRX)
ok, i'm confused now, i thought that was the map sensor...on the obdII harness the map sensor and TPS plugs are the same. i only have 2 sensors on the TB the IACV and the one in that picture so if that is the TPS where is the map sensor now................thanks for your help
Old Sep 7, 2003 | 07:40 PM
davken1102's Avatar
the map sensor should be on either the front of the TB or the top.
Old Sep 7, 2003 | 07:42 PM
TeStUdO's Avatar
The thing on top of your tb is the map sensor, the TPS is on the back of the TB just like it shows int he 2nd pic
Old Sep 7, 2003 | 09:15 PM
salbaje's Avatar
if theres no place for map on your tb it should be on the firewall
Old Sep 8, 2003 | 08:01 AM
Audi RS4's Avatar
Lover
Default Re: TPS help (salbaje)
thanks, ok so i don't have one on the TB, so how do i hook one up to the car now. here is a picture of my TB and i'm putting a B16A into an 98 civic with the OBDII to OBDI conversion harness.
Old Sep 8, 2003 | 08:10 AM
mmuller's Avatar
Mad Scientist
you hook up the map to the right vaccum line on top of the tb, the other thicker one is for evap. just like in the other pic.
Old Sep 8, 2003 | 08:16 AM
Audi RS4's Avatar
Lover
Default Re: TPS help (mmuller)
then just mount it to the firewall......
big thanks to all you guys
Randyb18
Aug 9, 2015 03:07 PM
bodiez
Oct 26, 2010 02:17 PM
D15JDMARIO
Feb 18, 2007 01:52 AM
ZC-EG-6
Aug 24, 2005 10:45 AM
killa_lude
Dec 28, 2003 07:09 AM
