TPS help
I got my engine in the car (B16A). started to hook everything up and realize that there is no TPS. i looked and my friends Type R to see where it is on his.ell it sits right ontop of the TB. i have 2 small hoses coming out of the TB where his TPS is. this is my first swap and i'm in a little trouble. does anyone have a picture of a B16A SiR II TB that i can see if i'm just missing it or something.everything was going good up to this point.
thanks
thanks
Look at the 2nd picture down. Its the sensor on the back of the TB (black). The one with the 3 wire plug connected to it.
http://www.geocities.com/phato....html
ok, i'm confused now, i thought that was the map sensor...on the obdII harness the map sensor and TPS plugs are the same. i only have 2 sensors on the TB the IACV and the one in that picture so if that is the TPS where is the map sensor now................thanks for your help
thanks, ok so i don't have one on the TB, so how do i hook one up to the car now. here is a picture of my TB and i'm putting a B16A into an 98 civic with the OBDII to OBDI conversion harness.
