i got question.. !!!?????
I got a D15B swap running with the JDM computer .. im having problems with Code 3 MAP sensor!!! when car in on and i plug the map sensor In car shuts off.. when map sensor is not plug the car turns on and runs rich and stall.. i mean ive put 2 different map sensor and same.. please help help help!! thanks guys..
Re: (pdiggitydogg)
yes sir i had to wire Map sensor st8r to the ECU.. cause the harness i have only had one plug and it was for the TPS.. so i wired the Map sensor with cable st8r from the computer to the sensor and still getting the same problem !!
Re: i got question.. !!!????? (D15JDMARIO)
For some reasion I'd be half tempted to check into you idle speed screw. I had a B16A in my EF and I remember having to tweek with it in order to connect all my sensors on the TB.
Good luck man
Good luck man
Hella_Fresh
10
04-05-2007 04:34 PM
