how does dsm intercooler fit delsol?
Old Sep 2, 2003 | 11:34 AM
nd8ch's Avatar
Default how does dsm intercooler fit delsol?
i know that its been done...but do i have to cut anything to make it fit except cutting the interooler itself? I tried test fitting the intercooler, and it seemas like the bottom part of the intercooler hits the lower plastic piece that holds the bumper on. Are you guys taking that lower plastic piece out so that the intercooler fits and no cutting or moding of parts? Or is this the only way to get the intercooler to fit wihtout without permanent moding of car parts? or is there a position im not getting so that everything in the car stays and the intercooler fits?
Old Sep 2, 2003 | 12:04 PM
Happyman's Avatar
Default Re: how does dsm intercooler fit delsol? (nd8ch)
I got a front mount and actually had to cut out the bottom part of the bumper that bolts on. Not a big deal.
Pengo's Avatar
only had to cut angle off of the lower pipe on the smic. the other end goes straight up to the stock resonator hole. once installed the ic sits at a slight angle inside the fender so it's not perfectly vertical up/down, but close. turn the steering wheel all the way so that you have room to work and play around with the fitment. it definitely works without cutting any of the car if ur patient and be creative
Old Sep 2, 2003 | 08:46 PM
nd8ch's Avatar
Default Re: how does dsm intercooler fit delsol? (Pengo)
so for the civic and del sol front end/bumper section are exactly the same?
Old Sep 3, 2003 | 05:22 PM
nd8ch's Avatar
bump
Old Sep 3, 2003 | 05:25 PM
ross1459's Avatar
i've seen it rigged up to go where the AC was. otherwise, i'm pretty sure it fits right in front of the radiator if you cut out the plastic grill. but it's just about touching it.
Old Sep 3, 2003 | 08:01 PM
nd8ch's Avatar
Default Re: how does dsm intercooler fit delsol? (ross1459)
i want to hook it up to where the intake resonator used to be...can i get some answers regarding this position for the intercooler? pictures are cool too
Old Sep 4, 2003 | 12:30 PM
Happyman's Avatar
Anything will fit with modification lol Just go try it. Mark off what needs to be cut and cut away. But, why not just get an FMIC? No funds, or want to be sleeper?
Old Sep 5, 2003 | 12:59 AM
nd8ch's Avatar
Default Re: how does dsm intercooler fit delsol? (Happyman)
no money...and doesnt seem necessary for my needs
KonThai
Jul 15, 2007 11:54 AM
ef dino
Jun 15, 2007 04:33 AM
birz
Sep 6, 2005 08:20 PM
jeremy.
Apr 22, 2004 07:51 AM
