Which intercooler to match half radiator?
I'm sure this idea has been thought of before, but after several searches I haven't seen mention of this...pls feel free to direct me to an existing H-T post.
Goal:
I'd like to run a C&R aluminum half radiator, and then find or make an intercooler which fills up the 2nd half.
Kinda like this...
This configuration would allow both heat exchangers to receive fresh ambient air, contrasted with the typical setup most of us use (intercooler in front of radiator).
Does any company make such an intercooler?
(or is there an OEM one off a stock car?)
Please post your opinions (with reasoning please) and more importantly, if anyone makes an intercooler in this "half radiator" size configuration
This is for a 90 CRX with Greddy turbo kit.
Thanks
Goal:
Kinda like this...
Thanks
Im sure this has been done before using a side mount DSM intercooler Search for "side mount intercooler" and you can see what the IC looks like.
I'm currently running with the 1g dsm smic you're referring to
....alas, these smics are a lot smaller than what I have in mind. In fact, mine is hidden in the bumper cavity where the stock resonator goes (below passenger headlight). These things are small
The intercooler I would want would be the same size (or nearly the same) as the C & R radiator.
Any ideas anyone?
Thanks
Any ideas anyone?
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nigel »</TD></TR><TR><TD CLASS="quote">just go to the junk yard and search for an intercooler thats the right size. then go have new tanks welded on. cant be that hard.</TD></TR></TABLE>
I'm trying to save myself from reinventing the wheel here. With all the H-T members out there, I'm hoping someone has already had some experience with this.
Last resort, of course, would be to hit the yards.
get a custom one made, or go to a junkyard, and find yourself a turbo shadow/daytona/caravan... A t2 car had a radiator & Intercooler that bolted to each other....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi »</TD></TR><TR><TD CLASS="quote">get a custom one made, or go to a junkyard, and find yourself a turbo shadow/daytona/caravan... A t2 car had a radiator & Intercooler that bolted to each other.... </TD></TR></TABLE>
I didn't know that. Now I know which cars to look for at least. Thanks..pretty interesting btw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Int3gra »</TD></TR><TR><TD CLASS="quote"> get a custom one made, ask earl or Arturbo.</TD></TR></TABLE>
Thanks...I'll follow up with them.
Thanks guys..
Thanks guys..
Do a search on ebay for intercooler, you'll get some ideas, maybe a saab intercooler, or an RX-7... Good luck!
Also, remember when plumbing, avoid too much turning...
-PHiZ
-PHiZ
Guest
Posts: n/a
i was going to do that.....
but, i'm just going bling spec front mount y0
the dsm stuff isn't that bad though. i mean...it can get heavy *** eclpises into the 13's easily
well, maybe a supra side mount?? the ones on the MK4 are pretty big, right?
Seanyriver04
Sep 8, 2007 11:44 AM
