**philips HID conversion**
Old Aug 14, 2001 | 09:25 PM
aliasb16a2's Avatar
New User
Default **philips HID conversion**
when converting to use the hid kit, what is the bulb heat difference? is there any chance of melting light assembly housings, or the lens? i have ctr headlights, and would love to have hids--but dont want to risk melting the lights. thanks---j.
Old Aug 14, 2001 | 11:37 PM
Ricehornet's Avatar
Default Re: **philips HID conversion** (aliasb16a2)
Ok, if you did some research on HIDs, and didnt just buy them for the pretty colors they make, you'll learn that HIDs use less wattage than halogen bulbs, i believe they are rated at 35W. Wattage is a measurement of power, power means heat...heat means....well...heat. So they will actually run COOLER than halogens.
So you are ok Good luck.
Old Aug 16, 2001 | 08:16 AM
bigTom's Avatar
Default Re: **philips HID conversion** (Ricehornet)
on my integra... even after running the hid's for hours... the lens never got hot once... once i turned on the hi-beams... talk about a lens getting hot and quick!
hid's use little power and do not get hot
SurferDude905
Lighting
Jul 2, 2010 03:39 PM
JFG Kevin
Mar 13, 2004 03:12 PM
JoJoNz
Nov 21, 2003 01:29 PM
SilverDc2
Nov 26, 2002 10:06 PM
-BlueGSR-
Nov 11, 2002 12:47 AM
