VAFC for turbo?
Old Aug 22, 2003 | 09:32 PM
vet_girl's Avatar
Default VAFC for turbo?
setting up the fuel management on a fmax turbo kit 7-9 psi T3/T4 with just DSM injectors and a VAFC.
I know this is not a great setup, but I don't have the money for a full EMS, so I want your opinion, should I stick with bothering with the MF2 , and tap into the fuel line and wiring the POS MF2, or just go the seemingly much simpler way with just injectors and a VAFC. Is this even possible?
EDIT: I just did a search, and it seems that a lot of people use the VAFC hack, but how safe is this?
Modified by vet_girl at 1:08 AM 8/23/2003
Old Aug 23, 2003 | 10:27 AM
CHK4TIX's Avatar
Default Re: VAFC for turbo? (vet_girl)
goto homemadeturbo.com they have a forum with even more info there
Old Aug 23, 2003 | 07:15 PM
rjr162's Avatar
The F-Max should come with the extra MAP sensor that the MF2 runs off of. You wire that up, plug the extra injectors off of the MF2 (which can run up to 8) and have it dyno tuned in 3D. Simple, effective, efficent. As I've said before, my brother is running high 12's using the MF2. Maybe not the *best* setup but it works well and is *alot* better in my mind then doing the V-AFC hack. That's using something as it wasn't designed to be used. Using the MF2 is using something that was designed to work that way
Old Aug 23, 2003 | 07:24 PM
del_parker's Avatar
do you have a VAFC? if not, i'd buy a hondata s200 w/ boost and get that tuned instead.
Bigplans06
Nov 28, 2004 08:14 AM
quik2kSi
Jul 17, 2003 07:09 PM
turbod16y7vtec
Oct 30, 2002 07:11 AM
CalvitoSol
Jun 17, 2002 09:13 PM
