Heat Wrap.
Well on my greddy kit is has one of the rubber hose return lines that you just clamp on. Well it calls to put heat wrap around it(which i did) but the heat wrap hits the block. Do you think the heat wrap will hold up against the block? I mean worst comes to worst I can just cut the block griddle cause thats what it's touching.
if my heat wrap can hold up for the past two years wrapped around the turbo manifold and exhaust housing I'm sure yours can hold up to block temps which are generally about 200 degrees cooler than the primary parts of the exhaust system...
speed shops but it ain't cheap.
either 1" or 2" wide 50 foot rolls. I got a 1" wide 50ft roll for $60
I think you can get it also from either http://www.jegs.com http://www.summitracing.com or http://www.mrgasket.com (mine was mrgasket heat wrap)
damn...what about the wrap to reflect heat from the a/c lines? i was reading the archives but most of them are through online stores...i'll try and look around locally...
>>either 1" or 2" wide 50 foot rolls. I got a 1" wide 50ft roll for $60<<
Ack!
http://store.hamiltonmarine.co...ts=10
This is where I got mine. 100' x 2" for $16.99. I used some of the other expensive stuff too for another project. This is *exactly* the same, except that it's not impregnated with that slimy goo that stinks for a month.
Ack!
mitoplease
Mar 19, 2009 11:29 AM
CO_CReX
Apr 29, 2007 06:44 PM
Sprockets
Sep 15, 2003 10:08 AM
