black soot, coming from exhaust
hi,
there is a pretty good amount of black soot building up on the backend of my car, comes out of the exhaust. I cant really see the soot coming out when the car is on, but it builds up every week. I checked my spark plugs and they seem perfect, (brownish redish color) only thing i notice wrong is, i get bad mileage (22 to 27 mpg) also my idle is sort of ruff. any ideas as to why the soot is coming out? thnx.
How often are you going into vtec? I have the black burn marks on my car from going into high RPMs (white car on the rear bumper) - it is normal...
List mods, do you have a fuel psi gauge... Little to vage to answer right now.
the only thing i have is denso iridium plugs jg lightspeed 8mm wires, srp 9:1 pistons, blockguard, and crower rods, aem cai, greddy evo cat back. btw is a d16z6. although i did have a problem a while back with the engine harness, it kept telling injector 3 to stay open all the time, but i had that fixed. is it possible that the injector is getting the wrong voltage? and spraying more than it should? also could it be my o2 sensor? i never replaced my o2 sensor after it was soaked in fuel. although i thought that since the o2 was soaked in fuel, it would send less fuel. i have gone to jiffy lube and they ran some injector cleaner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jazz215 »</TD></TR><TR><TD CLASS="quote">also, i do not go into vtec often. also i have an msd unit waiting to go in. should that help with the combustion? hopefully that will solve it. TIA</TD></TR></TABLE>
Yeah, MSD would help a little. I run MSD 6 box and blaster 3 coil, I love the quick throttle response. Will help burn everything in the combustion chamber.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 »</TD></TR><TR><TD CLASS="quote">so the best thing is to install a catch can and see what happens, right?</TD></TR></TABLE>
Na, a catch can will grab like a drop of oil vapor every 10+ miles, not actual fact, just a quess. That smoke you will not see... Catch can couldn't hurt, I made mine for $4 dollars.
I was thinking, would i have to replace my cat? what are the effects of to much gas going through it? at one point my exhaust was shooting out so much gas, i could fill up a jar while it just idled.
allshownogo
13
Jun 28, 2008 10:17 PM
