Exhaust stains...eewww!!
I have a Jspec D15 in my EG and im having a problem with my car blowing out black smoke, not alot.. but enough to stain my purrty white rear bumper.It usually happens when its at a higher rpm..I wanna paint my car but i want to get rid of this problem first..What would be my common problems?
Re: Exhaust stains...eewww!! (jdm_bones)
I'm havin the same problem....its definantly runnin rich..i hooked up my air/fuel ratio and at idle its pegged at "rich"....i just put in a rebuilt motor and it still does it...so could it be a faulty ecu?
Re: Exhaust stains...eewww!! (existanzcivicb20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by existanzcivicb20 »</TD></TR><TR><TD CLASS="quote">just start checking them out see how they look </TD></TR></TABLE>
Yea there are a few possiblities. I would just do a basic tune up and see what happends.
Re: Exhaust stains...eewww!! (cambopheonix56)
ive done nothing drastic, NGK wires, plugs, and the basic headers and exhaust..stock intake...keep in mind that even before i added all of these..it still did the same...and i am running a cat and a new o2 sensor....
Re: Exhaust stains...eewww!! (jdmkid_82)
fuel pressure too high. check to see what the pressure is at. should be somewhere around 36. and are you running a chipped ecu or stock?
Re: Exhaust stains...eewww!! (fmrprojects)
D15B's tend to put out a lot of black. My friends did, mine does, and few others that I have seen over time. It happens. Wut kind exhaust are you running? All I can recomend is getting some kind of down turn for an exhaust tip pointing it away from the bumper.
Re: Exhaust stains...eewww!! (99FBPSi)
Get some extension welded into the exhaust so that it doesn't sit RIGHT below the bumper. That's your problem. Your exhaust is to short and you're running rich.
Re: Exhaust stains...eewww!! (SOHC4life 96)
say for instance one of my buddies was messin with my MAP sensor while my car was running??? anyway that it would mess up the ecu?
Re: Exhaust stains...eewww!! (bmiller17)
your map sensor could have a lot to do with it running rich. A lot of piggyback systems change the resistance of the signal coming from the map or the iat sensor to change the fuel and ignition curves.
well no **** pendejo!!!! get the p28 and youll still puff out the same amount of smoke....we got rid of alot of smoke when we un fucked your whole wiring mess but i think we really need to trace that burnt wire back and see where it goes to....i know that ive seen coolant temp sensors that take a **** do the same also....itll be something small and stupid....ill see ya thursday so we can clean up that tranny ans finish up the h22 swap...if you want to help...later bro
RuffRhyno
03-18-2003 03:37 PM
VSM EXtasy
02-11-2003 01:18 PM
