The Hack Causing High Fuel Pressure?
Why would the hack cause fuel pressure to rise? When I installed my smc500 with NA, stock injectors, and a high flow pump. It caused the car to flood at 0% correction. Even with stock pump. Why would pressure rise as soon as the map is controlled by the hack?
i think the fuel pressure is high because the stock fuel pressure regulator does not have a big enough fuel return orifice, correct me if im wrong. i believe switching to an aem would help
he has a high flow pump... i believe if he doesnt use all that fuel ... say wiht a turbo the return isnt able to keep up with all that extra fuel...
HybridCoupe
Jul 6, 2002 03:48 PM
