grinding 3rd gear!! what to do to fix??
Old Aug 17, 2003 | 01:54 AM
shermanyang's Avatar
Default grinding 3rd gear!! what to do to fix??
okay i did search but this damn worm i got off the net is not allowing me to open certain windows. anyway, i heard that many people after changing from honda MTF or regular oil to GM Synchro Mesh tranny fluid did not have grinding anymore going into 3rd gear from 2nd at higher rpms. does anyone know where i can get some of this stuff to try out??
Old Aug 17, 2003 | 08:26 AM
svtec's Avatar
L D E S
Default Re: grinding 3rd gear!! what to do to fix?? (shermanyang)
maybe a GM dealership?
Old Aug 17, 2003 | 08:42 AM
EX-T's Avatar
yeah GM is the only place you can get it...and most likely your problem is your synchros and fluid is not going to fix bad synchros....Synchromesh is expensinve and I wouldn't even waste the money on it cuz it's not going to fix your problem...just double clutch coming out and going into those gears...
Old Aug 17, 2003 | 09:17 AM
Default Re: grinding 3rd gear!! what to do to fix?? (DSeriesBKilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSeriesBKilla &raquo;</TD></TR><TR><TD CLASS="quote">yeah GM is the only place you can get it...and most likely your problem is your synchros and fluid is not going to fix bad synchros....Synchromesh is expensinve and I wouldn't even waste the money on it cuz it's not going to fix your problem...just double clutch coming out and going into those gears...</TD></TR></TABLE>
yes it's expensive...i think someone said it's something like $7-$8 a quart, but at least it'd give me a piece of mind. this is just till i can buy a new tranny. anyway, thank you for replying...i'll try double clutching from 2nd to 3rd, never done it before but i'll try to learn.
Old Aug 17, 2003 | 11:05 AM
EX-T's Avatar
when I say double clutch I mean to push in the clutch for 2nd to neutral and again for neutral to 3rd....it's not hard....
ClemsonME
16
Aug 18, 2009 10:09 PM
$amGD3
11
Apr 17, 2007 08:15 PM
twenty
Dec 1, 2005 06:20 PM
Rpizzle
Apr 11, 2005 03:24 PM
elevatethis
41
Nov 24, 2003 12:02 AM
