Cracked sleeve..........
Old May 27, 2003 | 08:14 AM
vw-honda-hatches's Avatar
Default Cracked sleeve..........
Just pulled my head to do a headgasket on my STOCK 95 CX civic hatch.......
On Cylinder #1......ok this is hard to explain........
So if you looking at the sleeves from the top of the motor, and pretend the sleeve is actually 2 parts. The circle from in cylinder to the middle of the sleeve. and then the second part is from the middle of the sleeve to the coolant area.
I have a crack from the second area(coolant area) to the middle of the sleeve.
Then between the 2 sleeves part, I have almost a 2 tenths gap between them for about half a inch in length
I hope you understand this.......
Should I worry about this?
Old May 27, 2003 | 08:16 AM
sgT's Avatar
sgT
Default Re: Cracked sleeve.......... (vw-honda-hatches)
so you cracked the water jacket. i would worry about that.
Old May 27, 2003 | 08:20 AM
Default Re: Cracked sleeve.......... (sgT)
How so? In you meaning i should find another motor?
Edit- it does have a crack on the cylinder side of the sleeve
Old May 27, 2003 | 09:18 AM
sgT's Avatar
sgT
you can always see if resleving can repair it.
Old May 27, 2003 | 09:45 AM
Nextelbuddy's Avatar
i had that same problem on my ITR motor sold it to my friend and hes curently getting it resleeved. 700 bux
Old May 27, 2003 | 01:23 PM
ok my machine shop guy who is a honda guru (also installed dart sleeves for honda)
Told me the sleeve delaminated itself. I should get a new block.
Stuff i forgot to ask and they are closed.
- Since the inside part of the sleeve isnt cracked, wouldnt the headgasket still seal it? and for how long? would there be any long term affects on it?
Old May 27, 2003 | 06:31 PM
any real techies in here?
Old May 28, 2003 | 10:26 AM
X-Mazda 3 Racer's Avatar
I would not worry about the small crack behind the sleeve. A re-sleeve job will fix that right up, no problem.
Old May 28, 2003 | 02:49 PM
Default Re: Cracked sleeve.......... (GoldenEagleMfg.com)
yes, but i dont want to resleeve it. i want to know if i can throw a new headgasket on it, with leaving that sleeve how it is, and will it burn coolant? and be a waste of my time?
Old May 28, 2003 | 05:26 PM
Blaze45's Avatar
Brrraaaap!
If the sleeve is cracked and leakin into the cyl. you will brun coolant. You car will run, but not very well... Depends on how bad it is. post a pic.
Blaze
Old Aug 17, 2003 | 10:35 AM
civictypenos's Avatar
Default Re: Cracked sleeve.......... (Blaze45)
im having the same problem,the cylinder is not cracked all the way through,its looks perfect on the inside where the rings touch,the crack is on the outside,where the coolant touchs,the sleeves look like they are 2 pices.
Old Aug 17, 2003 | 11:23 AM
Default Re: Cracked sleeve.......... (civictypenos)
pics
alpha_1
Engine Machining & Assembly
Aug 10, 2017 06:04 PM
ysofasts2k
Mar 30, 2010 06:36 AM
SLO Sol
Sep 8, 2007 05:50 PM
rice a roni
Feb 14, 2006 08:17 AM
XES
Mar 28, 2003 09:38 AM
