Eagle rod bolt upgrade...is machining really necessary for the new bolts?
Old Aug 13, 2003 | 07:27 AM
TheSwift1's Avatar
Default Eagle rod bolt upgrade...is machining really necessary for the new bolts?
So i'm lookin through the ARP website (www.arp-fasteners.com), trying to educate myself on the world of fasteners and whether or not i need to upgrade the bolts on my Eagle rods, then i notice the specs on the ARP Custom Age 625+. According to the site, model no.300-6708 has the same exact specs(in terms of sizing) as the ARP 2000 1.5 that come stock with the Eagles...if this is the case, then why are people saying that machining is necessary when upgrading to these particular bolts? someone please educate me!
http://arp-fasteners.com/media...t.pdf
scroll down to the aftermarket rod bolts sizing section...
Old Aug 13, 2003 | 07:46 AM
ArtOwnzMe's Avatar
Default Re: Eagle rod bolt upgrade...is machining really necessary for the new bolts? (TheSwift1)
you cant fit a bigger bolt in a smaller hole.
Old Aug 13, 2003 | 08:28 AM
lsvtecvx's Avatar
Default Re: Eagle rod bolt upgrade...is machining really necessary for the new bolts? (ArtOwnzMe)
The bolt fits in the hole from what I understand(if you look at the bolts that come with the Eagles, its fat than narrows at the center,than widens out again at the thread), its because the upgraded bolts require more torque. and it throws off
the bore alignment of the rod, I think??
Old Aug 13, 2003 | 02:55 PM
TheSwift1's Avatar
ttt
Old Aug 13, 2003 | 03:12 PM
ArtOwnzMe's Avatar
Default Re: Eagle rod bolt upgrade...is machining really necessary for the new bolts? (lsvtecvx)
if the bolts fit, there would be no need to take them to a machine shop
Old Aug 13, 2003 | 03:15 PM
lsvtecvx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecvx &raquo;</TD></TR><TR><TD CLASS="quote">The bolt fits in the hole from what I understand(if you look at the bolts that come with the Eagles, its fat than narrows at the center,than widens out again at the thread), its because the upgraded bolts require more torque. and it throws off
the bore alignment of the rod, I think??</TD></TR></TABLE>
Like I said before.Maybe you didnt catch it.
Old Aug 13, 2003 | 04:18 PM
TheSwift1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArtOwnzMe &raquo;</TD></TR><TR><TD CLASS="quote">if the bolts fit, there would be no need to take them to a machine shop </TD></TR></TABLE>
go away..
lsvtecvx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheSwift1 &raquo;</TD></TR><TR><TD CLASS="quote"> According to the site, model no.300-6708 has the same exact specs(in terms of sizing) as the ARP 2000 1.5 that come stock with the Eagles
scroll down to the aftermarket rod bolts sizing section...</TD></TR></TABLE>
Like I said the difference is in the center of the bolt, the upgraded bolts do not get skinnier.
8VEYBEYB
Aug 11, 2009 08:57 AM
EnzoSpeed
Sep 22, 2005 03:20 PM
DRAGLS
Feb 5, 2004 01:22 PM
dsadas89das78934
Nov 7, 2003 11:59 PM
GOLDBERG
Sep 5, 2003 03:04 AM
