NOt holding boost. 1990 honda acura
Old Aug 11, 2003 | 09:23 AM
miege44's Avatar
Default NOt holding boost. 1990 honda acura
i have two problems today, so sit down and have a
is it possible for the intercooler piping to not hold boost? at first i thought my wastegate was not holding boost, but after a few drinks and replacing it, it seems like i am still not holding boost. should i get the piping welded rather than using the rubber connectors that i am using now?
Old Aug 11, 2003 | 10:40 AM
twkdCD595's Avatar
Default Re: NOt holding boost. 1990 honda acura (miege44)
yes obviously if there is a leak anywere it will not hold boost.
check your charge piping very well and use good clamps that dont back off.
Old Aug 11, 2003 | 02:28 PM
miege44's Avatar
Default Re: NOt holding boost. 1990 honda acura (twkdCD595)
yeah, i havent looked at the car but it seems like your problem is a leak somewhere in the wastegate and/or one of the boost lines. but ill be there in the morning, ive got my plane ticket in hand and we are going to fix that assshit.
Old Aug 11, 2003 | 04:19 PM
Accord94DX's Avatar
what connectors are you using?
Old Aug 12, 2003 | 08:27 AM
miege44's Avatar
Default Re: NOt holding boost. 1990 honda acura (Accord94DX)
just some silicon material ones that i bought from a local guy along with the clamps, he was running on his 4th gen car that he put back to stock. how could i pinpoint the leak?
EDIT: the car is a 1990 honda acura
Old Aug 12, 2003 | 08:30 AM
miege44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miege44 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i havent looked at the car but it seems like your problem is a leak somewhere in the wastegate and/or one of the boost lines. but ill be there in the morning, ive got my plane ticket in hand and we are going to fix that assshit. </TD></TR></TABLE>
alright partner, you're my man, im countin onyou
Old Aug 12, 2003 | 08:45 AM
SearchBeforeUPost!'s Avatar
what the hell is going on here? Why are you replying to yourself? Why the hell do you keep calling your car a "Honda Acura"?
And why the hell are you running OEM exhaust on boost?
Sounds like you need to step away from the for a little while and get your ducks in a row.
Old Aug 12, 2003 | 03:11 PM
teamlegacy's Avatar
Default Re: NOt holding boost. 1990 honda acura (Bda91acc)
:bs:? If this is legit...check vacuum lines.
Old Aug 12, 2003 | 04:27 PM
miege44's Avatar
Default Re: NOt holding boost. 1990 honda acura (teamlegacy)
replying to myself? sdorry, i share my accoutn with my brother up in va, because niether of us post too much...
honda acura? well what do you tink it is?
the OEM exhaust is still there only for lack of funds, friend. i bought the setup as a 'kit' from a local guy for a steel, i know that it is robbing power. i dont avhe any spare change whatsoever to spend, i have bills :-( i have made a post about my setup not holding boost before but it was locked..
i dont think vacuum would have too much to to with it, it just doesnt build boost like it used to :-) one thing i don't know is if the dsm turbo is internal or external wastegate, will i have to get a rebuilt or newturbo if the wastegate turns out to be bad? hwo do i check to see which connector isnt holding buoost, if it is in fact a connecter?
too many drinks day after ay= un corrected typos
Old Aug 13, 2003 | 08:16 AM
miege44's Avatar
bump, i need my car rnning right
Old Aug 13, 2003 | 09:47 PM
urbanracer93's Avatar
first what is a honda acura, and to answer one of your questions all stock dsm turbos are internally wastgated and if the wastegate is bad the you can have it rebuilt.
*edit* i cant type for **** tonight,lol
Modified by urbanracer93 at 6:59 AM 8/14/2003
Modified by urbanracer93 at 7:00 AM 8/14/2003
Old Aug 13, 2003 | 09:54 PM
eL's Avatar
eL
english owns you all!
Old Aug 14, 2003 | 08:56 AM
iam7head's Avatar
Default Re: (R3LL 1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R3LL 1 &raquo;</TD></TR><TR><TD CLASS="quote">english owns you all!</TD></TR></TABLE>
exatly..bot joo aiint h3lpin'muchh neiitha..
okay okay..
check list
-intercooler leaks(leak downtest please)
-ic piping(chargepipe=70$ of the time, check silicone connector)
-vaccum line, BYpass valve(bov) and missing link.
-turbo(shaftplay? f-cked fins?)
how big is your downpipe now?
Old Sep 5, 2009 | 08:29 AM
miege44's Avatar
still not runnin, any suggestions?
T9U4ReBgO
Mar 6, 2008 09:11 AM
playahwitgame
Sep 19, 2006 09:08 AM
dgonzals
Nov 29, 2003 07:53 PM
smoothludey2
Feb 25, 2002 02:39 PM
1.8EG-T
Jan 24, 2002 12:36 PM
