Seperate oil system for turbo???
Old Aug 8, 2003 | 10:59 AM
FuzzyGreen's Avatar
Default Seperate oil system for turbo???
Is it possible to have a small electric pump and small oil tank to feed the turbo and return directly so you don't have to connect to your engine oil system?
Pros:
1. You could have the pump run on a timer so you wouldn't need a turbo timer, only a pump timer. No hassle with waiting to shut off your engine after a hard run.
2. You avoid oil sending unit headaches (like breaking the sender inside the block like I did)
3. You avoid oil return headaches
4. Keeps the engine oil cooler since that hot turbo oil isn't there
5. Makes installing a turbo A LOT easier
6. Could incorporate a small cooler
cons:
1. oil pressure wouldn't change with rpm
2. would take up some under hood space
3. more expensive then the standard system
I think I will look into making a kit like this.
Old Aug 8, 2003 | 11:20 AM
mskibbz-T's Avatar
Default Re: Seperate oil system for turbo??? (FuzzyGreenCarpets)
It doesn't sound bad conceptually, but this has been brought up before and shot down for a few reasons... Search and ye shall find
Old Aug 8, 2003 | 11:31 AM
Accord94DX's Avatar
Default Re: Seperate oil system for turbo??? (mskibbz-T)
using a GE sammich adapter takes a LOT of pains out of the turbo oil system. Drilling the oil pan is a pain in the ***, but not too bad.
Old Aug 8, 2003 | 12:37 PM
Howitt's Avatar
Default Re: Seperate oil system for turbo??? (Accord94DX)
I have sammiches in stock from GE with all sorts of adapters to $90 shipped if you want one
Old Aug 8, 2003 | 02:54 PM
FuzzyGreen's Avatar
Default Re: Seperate oil system for turbo??? (Howitt)
Do those adaptors supply enough oil for the turbo? Can they be used on engines that have the stock oil/water oil coolers?
AccordVT
Jul 30, 2008 07:51 PM
POGRacing
Feb 5, 2008 03:14 AM
b4tn
Dec 30, 2004 04:00 PM
B18c1CivicTurboed
Jun 3, 2003 08:33 AM
89civic1.8T
Jun 19, 2002 01:42 PM
