Code 22, Make It Go Away!!!
Old Aug 4, 2003 | 05:42 PM
SlippylesKB's Avatar
Default Code 22, Make It Go Away!!!
Here's the scenario:
JDM GSR Swap, 93 Civic CX Hatchback. Throws code 22, and that's the only code for the entire swap. How can I get rid of this?
I just got done reading that I could plug one wire in both ends of the sensor and be done with it. Good or Bad idea? Will this hurt anything?
And on a side note, my corner lamps won't be on when I have the headlights/corners on, but it will blink. Also my rear brakelight does not want to light up either. Coincidence?
Old Aug 4, 2003 | 06:46 PM
Default Re: Code 22, Make It Go Away!!! (SlippylesKB)
up
Old Aug 5, 2003 | 02:05 AM
c'mon guy's I'd like to get this thing running sometime.
Old Aug 5, 2003 | 02:14 AM
im_poor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlippylesKB &raquo;</TD></TR><TR><TD CLASS="quote">
if you do that you won't have vtec...correct?
Old Aug 5, 2003 | 07:35 AM
Default Re: Code 22, Make It Go Away!!! (im_poor)
I dunno, that's why I'm asking. Just tryin to get this thing running properly.
Old Aug 5, 2003 | 07:44 AM
Dan GSR's Avatar
VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
did you even wire up your vtec lines??
Old Aug 5, 2003 | 07:51 AM
yaya's Avatar
Default Re: Code 22, Make It Go Away!!! (Dan GSR)
your jdm engine does have a vtec solenoid...duh, but no oil pressure sensor....grab a usdm vtec soleniod and pressure switch
3 small bolts and its off
Old Aug 5, 2003 | 07:53 AM
yaya's Avatar
Default Re: Code 22, Make It Go Away!!! (yayaRl337)
you did notice that your harness has 2 wires left over right? those go the the oil pressure sensor
what ecu?
cx harness?
you added the vtec wires?
Old Aug 5, 2003 | 08:05 AM
salbaje's Avatar
yes replace your solenoid with a usdm one
Old Aug 5, 2003 | 08:09 PM
yes I saw the 2 wires left over and I wired the black one to a ground and the other into the wiring harness and to the ecu at D6. I probably just have a bad sensor.
Old Aug 5, 2003 | 08:32 PM
ITRacer121's Avatar
make sure the wire has contenuity/ making a full circute (sorry i spel like a 3 yr old) with a volt meter
mine was doing this and I could not find Vtec either but now it is fixed an Vtec is GOOOD
it would also make it easier to diagnose if you told us what ECU/ wire harness you are using?
JDm ECU doesnt have a pressure switch so I imagine you are running a US ECU
EGKREW
Oct 31, 2008 05:56 AM
22lude
May 2, 2005 05:59 AM
specv5150
Jun 11, 2004 02:47 PM
undefinedcrx
Mar 12, 2004 01:11 AM
SlippylesKB
Sep 3, 2003 07:46 AM
