GSR Swap Code Problems: Code 22
Old Aug 30, 2003 | 08:32 PM
SlippylesKB's Avatar
Default GSR Swap Code Problems: Code 22
Ok, here's the story. I did my swap (JDM GSR) about a month ago and originally I threw a Code 22. So I put my buddies chipped ECU in there and it fixed the problem. I even put in my Stock p72 in it to make sure... and no codes. I have had a chipped ECU for about a month now and have had no problems, until tonight.
Here's my question... I know that a JDM GSR doesn't look for the Vtec Pressure Solenoid (what causes the Code 22). So how come if I have a chipped ECU it still throws this code... shouldn't it have eliminated that sensor completely?
Any suggestions on how to get rid of this pesky problem of mine?
Scott
Old Aug 31, 2003 | 06:58 AM
Default Re: GSR Swap Code Problems: Code 22 (SlippylesKB)
Nothin?
Old Aug 31, 2003 | 07:03 AM
eg6ajk's Avatar
no only the JDM OBDII ecus do not read the sensor and non-obd Mugen program.
to prevent the code. simply take the oil pressure wire and splice it to the vtec solenoid wire., less then 10 seconds and no more problems or codes.
Old Aug 31, 2003 | 08:17 AM
Default Re: GSR Swap Code Problems: Code 22 (eg6ajk)
Do I still keep the oil pressure wire grounded and simply connect the blue wire to the funky green/yellow Vtec wire? Or do I connect both the ground and blue wire to the funky green/yellow Vtec wire?
Thank You for your help.
Scott
Old Sep 2, 2003 | 05:16 PM
PHiZ's Avatar
I believe you just take the vtel oil signal wire, and connect it to the vtec solenoid line.
eg6ajk: can you explain why this works?
-PHiZ
Old Sep 2, 2003 | 05:27 PM
eg6ajk's Avatar
Default Re: GSR Swap Code Problems: Code 22 (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">I believe you just take the vtel oil signal wire, and connect it to the vtec solenoid line.
-PHiZ
indeed. splice the oil presure signal wire to the vtec solenoid wire. it works as it provides constant feedback to the oil pressure sensor.
simple 10sec job. take a look, below.
Old Sep 2, 2003 | 05:38 PM
poison's Avatar
Yes, the oil pressure sensor will still need to be grounded. However, like eg6ajk said, simply take the Blu/Blk wire and splice that to the VTEC solenoid which is Grn/Wht wire.
You can also put a US spec VTEC solenoid assembly on the motor and hook the VTEC oil pressure sensor as factory too if you have one lying around. Other than that, no point.
Old Sep 3, 2003 | 07:46 AM
Default Re: GSR Swap Code Problems: Code 22 (poison)
Cool, thanks fellas. I fixed the problem by moving my ground from underneath the transmission ground to on top. So hopefully that fixed that, if not I will indeed do some splicing. Thanks
Scott
Jdmkids Manny
17
May 12, 2016 02:18 PM
B16tyler422
Jun 16, 2007 05:04 PM
Metal Head
Sep 28, 2006 11:39 PM
Hondasaurs
May 5, 2003 03:00 PM
pelotudo
Jan 30, 2002 11:43 AM
