obd 1 swap in a 88si
ok here is my friends porblem...
he's using a pre obd 1 to obd 1 conversion from blownhatch...
the car starts up and idles.... but it doesnt run.. when you rev it, it dies...what would cause this??
TPS readings are screwed.
Grab a voltometer and ground it to the Grn/Wht wire, put the other voltometer terminal to the Red/Blue wire, and make sure at idle the voltage for the TPS is at .5 volts and at WOT it's set at .45 volts.
That will fix your problem.
