tps and map problem?
Old Apr 9, 2009 | 09:43 PM
b18swapef's Avatar
Default tps and map problem?
i recently pulled out the chiltons and started checking my sensors with my multi meter because my car just isnt running right. so i check my map sensor and the green to yellow shows 5 volts but the green to white shows .6 volts so i replace the wire all the way to the ecu and still only shows .6 volts does this mean that my ecu is bad? also i hooked it up to my tps and my starting voltage with it all the way closed is .19 and with it all the way open is 3.8 does this mean my tps is short or it needs to be ajusted? any help would be graet thanks
Old Apr 9, 2009 | 10:00 PM
b18swapef's Avatar
Default Re: tps and map problem?
bump i am really needing answers i could find anything when i searched
Old Apr 9, 2009 | 11:27 PM
Oreo-TeCk's Avatar
not every wire is goinna get a 5 volt reference...sometimes you will get a sensor sensor wire and a wire with 5volt reference and then u'll have your ground...and voltage at close throttle is pretty low... but voltage at wide open throttle usually is around 4.2-4.3.... what kind of problems are you running into??
Old Apr 10, 2009 | 12:08 AM
b18swapef's Avatar
it idles rough ,has a bad miss and it feels like its being held back and my chiltons said the wire should have 5volts and thanks for the reply
Old Apr 10, 2009 | 12:20 AM
Oreo-TeCk's Avatar
a number of things can cause a rough idle for example bad motor mounts... things can cause a misfire is is anything from a ****ed up cam or lifter,stuck closed injector,bad spark plug but if ur thearoy is bad ecu...switch it out with a friend and see what happens
Old Apr 10, 2009 | 07:16 AM
mouab18c1's Avatar
you might need to adjust your tps i can tell that its not calibrated to the right specs according to your post. it should be 4.5 at WOT and .5 at closed if i remember right. search to make sure
Old Apr 10, 2009 | 10:41 AM
b18swapef's Avatar
all motor mounts are good i think it is the miss thats fin up the idle but i am gonna check my injectors and order a new pr4 mt ecu cause none of my freinds have one and i will get back to you guys and let you know how it goes and thanks for the reply
Old Apr 11, 2009 | 10:37 AM
mouab18c1's Avatar
BTW what car and motor is this anyways?
Old Apr 11, 2009 | 12:33 PM
b18swapef's Avatar
88 civic hatch dx with a full integra wiring harness and a 97 b18b converted to obd0
Old Apr 11, 2009 | 01:06 PM
mouab18c1's Avatar
so your running an ls ecu correct?
Old Apr 11, 2009 | 01:54 PM
b18swapef's Avatar
yup pr4 out of a 91 integra
Brandon Hartman
Nov 21, 2018 02:03 PM
ATS*Mark
21
May 8, 2006 07:29 PM
Gant
May 18, 2005 08:47 PM
baxter04
Jul 5, 2004 08:19 PM
SiR HatchAlot
Jan 12, 2004 12:06 PM
