jdm gsr block/ si head
Old Aug 8, 2001 | 08:34 AM
Gong Show's Avatar
Default jdm gsr block/ si head
i was trying to get info on another board, thought id give it a try here...
im thinking about going with a gsr block/si head... the first plan was
to see if i just kept it all gsr and went with ctr pistons/cams, would i run
into any valve clearance problems and also compression???
but now im thinking about if i keep my stock pistons(10.6), and go with
spoon or mugen head gasket and ctr cams, what will the compression be raised
to and what kinda of hp can i get out of this... this motor will be in a ls teg..
i've seen one kid with a set-up close to this running mid 13's... he had the basic bolt-ons.
b18c1 block
b16a head
itr manifold,intake valves,cams,ecu
ctr pistons
comptech airfilter
pyr cam gears
portflow inner springs&retainers
2 1/4 custom exhaust
hi flow cat
nos fpr
my set-up would be almost the same, but stock 10.6 pistons
with mugen or spoon head gasket, ctr cams itr/portflow valvetrain and jdm 4-1 header/hi-cat...
if possible help me out...
Old Aug 8, 2001 | 08:43 AM
WAFFLES's Avatar
Default Re: jdm gsr block/ si head (LS(litesleeper))
Your set up will be pretty nice. I recommend ITR pistons. Slightly higher comp. but its up to you. Good Luck
Old Aug 8, 2001 | 09:12 AM
Gong Show's Avatar
Default Re: jdm gsr block/ si head (WAFFLES)
i was thinking going with the jdm itr pistons, the jdm gsr pistons
which i have now have the same compression as us itr pistons... and being that im on a budget
i was just seening which headgasket out there can raise the most compression... plus i would still have to get
the ctr cams,valvetrain,ecu chipped,jdm header&t-body bored... trying to save money, plus i really just want the car
set-up for raod racing. all-mota cars for drag are a waste of time if you dont have the money to spend... you might as well
just go turbo(imo)... i love all-mota, my goal is only low-mid 13's all-mota. and i know with this set-up you can get pretty far and still have a reliable car... i'll put together a few shopping list with piston/and without plus above parts..
streetsold6teeny8
Apr 3, 2010 11:13 AM
JDM_EK_JOE
13
Mar 9, 2009 07:41 AM
jdmitrhatch
Apr 25, 2004 07:35 PM
crxste
Aug 19, 2003 08:16 PM
Houston Hatchback
Apr 24, 2002 12:02 AM
