Vtec not workin
Old Aug 3, 2003 | 10:48 AM
roydogg's Avatar
Default Vtec not workin
95 gsr swap into a 93 hb cx. It drives fine just no vtec. the car just came out of the shop for body work and now it doesn't work. any ideas? Any help will be thankful
Old Aug 3, 2003 | 12:19 PM
MEANB18's Avatar
Default Re: Vtec not workin (roydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg &raquo;</TD></TR><TR><TD CLASS="quote">95 gsr swap into a 93 hb cx. It drives fine just no vtec. the car just came out of the shop for body work and now it doesn't work. any ideas? Any help will be thankful </TD></TR></TABLE>
I don't think the CX has vtec stock, did you wire for vtec with the wiring harness? Are there any CEL's?
Also, what ECU are you using?&gt;
Old Aug 3, 2003 | 01:33 PM
sslude's Avatar
Default Re: Vtec not workin (MEANB18)
well the cx motor probably didnt have vtec,but he did a gsr swap. check the solenoid and oil and all that. is it throwing a code? reset the ECU and try again.
Old Aug 3, 2003 | 02:12 PM
redline201's Avatar
Default Re: Vtec not workin (sslude)
https://honda-tech.com/zerothread?id=164863
this will help
Old Aug 4, 2003 | 12:54 AM
roydogg's Avatar
Default Re: Vtec not workin (redline201)
Thanks for the help fellaz. But it's still not working right. Just found out that the cars a vx not a cx if it makes a difference.
I did a compression test today on it and it came up bout 225 all across but cylinders 2 and 3 were soaked with oil all over the threads, could that be the problem? He's not burning any oil either.
It also sounds like his vtec is opening up just not the secondary valves screaming like it used too.
Old Aug 4, 2003 | 03:06 AM
7PSiEF9ZC's Avatar
Hey check the soliniod valve make sure it's working right. Also you said the car just came out of the body shop right ? Check all connections , grounds , etc. maybe they body shop disconnected something that would effect vtec and either forgot to re-connect it or didn't know it was loose. I've seen alot of body shop f***-up's come into the shop I work at.
Old Aug 4, 2003 | 10:15 AM
roydogg's Avatar
Default Re: Vtec not workin (7PSiEF9ZC)
Checked the solenoid it's fine we're just gonna try abother ecu next.
chevmaro
Mar 27, 2011 01:31 PM
blue_flames05
10
Oct 12, 2007 11:26 AM
Straits514
Apr 19, 2006 12:29 PM
rdaggett
Mar 8, 2005 09:09 AM
1sick4door
Jan 22, 2002 04:47 AM
