idle surge???
Old Aug 2, 2003 | 10:03 AM
ic0n's Avatar
Default idle surge???
lately my car start to idle surge and all the sudden the car shut down does anyone know what is happening?
thanx
Old Aug 2, 2003 | 10:26 AM
HONDADNA's Avatar
Default Re: idle surge??? (ic0n)
in what condition does happen? engine cold or warm? does only happen at cold start up's and the it goes back to normal once it's hot? or does happen at hot or cold conditions?
Old Aug 2, 2003 | 01:01 PM
94dxt's Avatar
Default Re: idle surge??? (HONDADNA)
Sorry to steal the thread, but mine surges only on cold start a few times then stops.What's likely the cause?
Old Aug 2, 2003 | 03:19 PM
MidoriEK9's Avatar
My Prelude surges when I let off the gas, but its because the IACV sensor is bad.
Old Aug 2, 2003 | 07:36 PM
crxhybrid1320's Avatar
Default Re: (MidoriEK9)
Remove the Idle Air Control(IAC) off the back of the intale manifold. Its only two 12mm bolts to rmove and leave the coolant hoses connected also. Spray carb cleaner into the intake manifold hole on the back of the manifold and into the hole on the IAC valve to clean the carbon out.
GSRicer
Jul 5, 2009 08:34 PM
DIYMIKE
Nov 14, 2004 06:03 PM
See Are X
Mar 24, 2004 06:09 PM
redex94
Jul 10, 2003 11:43 AM
b16vteccx
Mar 22, 2002 06:16 AM
