pipe/tube beader tool - need one, can't find one
Want to find a pipe beader for some custom metal lines. Most common size will probably be 3/8", 1/2... maybe even up to 1". any suggestions?
i think he wants a beader not bender?! I've thought about running hard lines for oil feed. It'd look clean if done w/ aluminum shaped nicely around the block. I've seen them for 1/4"-1/2" or so but nothing 1" big.
Any hard lines run for an oil feed really need to be flexable (braided). A hard line will break due to metal fatigue. The constant vibration will cause the line to break, pumping all of the oil out spinning bearings or worse.
Material question on oil fittings/lines (steel, brass, alum, stainless???) also question on flexibil
reignofchaos
Aug 9, 2003 04:40 AM
