Proper way to install ARP head studs
Old Jul 26, 2003 | 11:21 AM
Boost2NA's Avatar
Default Proper way to install ARP head studs
Ive been told by 3 different people to install them 3 different ways. I know the torque specs to torque them to im just confused on how to put them in. First I was told to put them in hand tight then put the nut on and start to torque them. A second person told me to bottom the stud out and then back it off one half turn then to torque them on. Lastly I was told put the stud in and actually torque the stud to 10 ft. lbs and then put the head on. Can someone please tell me the correct wat to install the studs in my block? Thanks
Old Jul 26, 2003 | 12:03 PM
untitled's Avatar
Default Re: Proper way to install ARP head studs (Boosted99Si)
i need to know this as well. i am to lazy to look at the directions right now. they over at the shop. ill post when i find out for sure.
Old Jul 26, 2003 | 12:16 PM
the-anti-crack's Avatar
Default Re: Proper way to install ARP head studs (88crx91integra)
i just installed mine yesterday. the paper work that comes with them clearly says make them hand tight. do not torque them, just make sure they are all the way threaded down.
Old Jul 26, 2003 | 01:18 PM
Boost2NA's Avatar
Default Re: Proper way to install ARP head studs (the-anti-crack)
I just wanted to clarify that you do put them in hand tight. The directions also say to torque them at 65 ft. lbs. but GE says go to 80 with them. Im gonna go to 80 even though the directions clearly say 65
Old Jul 26, 2003 | 05:54 PM
PWRVTEC's Avatar
I used blue lock tite in the block after cleaning the threads good, and hand tighten them to like about 10ft-lbs and then torqued the head to 78ft-lbs no problems so far at 10 psi
Old Jul 26, 2003 | 08:41 PM
accordking's Avatar
Default Re: Proper way to install ARP head studs (PWRVTEC)
#5 setting on my 1/2 inch I/R and let it RIPP! j/k!! lol! 65 to 80 is ok. Hand tight when installing into block WITHOUT molly lube.
Old Jul 26, 2003 | 09:37 PM
Default Re: Proper way to install ARP head studs (accordking)
my instructions said to torque to 70# with the provided lube, and 85# if using 30wt motor oil. i am also using the inline pro 2 mm head gasket....and to use that you are supposed to touque 10% over stock which would be 66# i belive.
i torqued to 70, i hope all turns out
Old Jul 28, 2003 | 03:55 PM
untitled's Avatar
which end do you put tin the block? the short threads or the long. short right?
Old Jul 28, 2003 | 03:57 PM
Sonny's Avatar
When I installed mine, I screwed them into the block using 10 ft-lb. Finger-tight resulted in all of the studs sitting at different heights. Additionally, I know some people have had problems with the studs backing out when screwed in only finger-tight.
Sonny
Old Jul 28, 2003 | 04:12 PM
untitled's Avatar
Default Re: Proper way to install ARP head studs (Sonny)
but which end do i thread in the block? the end with the short threads or the end with the longer amount of thread?
Old Jul 28, 2003 | 04:57 PM
Sonny's Avatar
The nuts will only fit on one end of the stud. It's the side that they don't fit on that goes into the block.
Sonny
Old Jul 28, 2003 | 05:08 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">
Sonny
On my D16 ARP studs, the nut can go on either end. ARP (as well as a few others on this board) told me the long thread end goes in the block.
HTH
Kr4nG
Nov 6, 2009 02:48 AM
95_red_dc
Aug 31, 2008 09:28 AM
ivt-t
Feb 8, 2007 09:15 PM
itralex
Oct 17, 2004 08:29 AM
SOHC_MShue
Jun 6, 2004 12:54 PM
