idle oil pressure
my b18b at idle is having a static 60psi oil press. That seems huge!
tried two different grounds with same pressure results
unit is a vdo with vdo sender
electrical
thanks
electrical
thanks
was your motor just rebuilt? I've seen new motor run about 45-50 psi during break in at an Idle but, 60 should be around cruising rpm. If it was just rebuilt maybe the clearances are really tight. Just a thought
check your PCV and crancase vent systems, make sure they're not clogged up.
also, rev the motor to 3500 rpm or so while its sitting and see what oil pressure is there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Audipwr1 »</TD></TR><TR><TD CLASS="quote">you think 40psi is too high for 2k at no load?</TD></TR></TABLE>
sorry... you had posted before i hit 'send'
disregard
disregard
thanks RJ
I suspect the air in the line and sender skewed it, but once driven, shut down, and driven again the air escaped allowing a more accurate reading
electrical, but going with the endyn site, i setup a remote system as to not put the added torque of a big sender on the block. ill post up some pics of the setup once i find a pace to host em
still have use of the stock warning light as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Audipwr1 »</TD></TR><TR><TD CLASS="quote">electrical, still have use of the stock warning light as well</TD></TR></TABLE>
stock warning light is useless..... it might as well be green and shaped like a dollar sign.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">
stock warning light is useless..... it might as well be green and shaped like a dollar sign.</TD></TR></TABLE>
oh god that made me laugh for like 5 mintues straight
thx
thx
Are you sure it doesn't drop when the motor heats up more? My car on cold start up will read about 60psi, then drop to 30-40 after 5 minutes, then once its completely warm will be between 15-20.
