t3/60-1 vs t3/t04e
thanks, but i'm talkin bout the actual size of the turbo itself, i'm gunna have some really tight fitment, and i wanna know what would be the best bet for space. is the t3/60-1 larger than the t3/t04e?
Well it depends on which one you get , compressor housing standard is a T04S which is a .70 A/R but you can get it by Turbonetics in their 60-1 Hi Fi which is a T04E housing .60 A/R What mani are you using?
buy my SFP manifold & DP (hopes you have a b20 prelude)
I think the t3/t40e is smaller, but i don't know by how much. try
http://www.turboneticsinc.com
if your space is limited, get a 60-1 HiFi, which is a 60-1 wheel shoved in a lil t04e housing. It is only about 10-20% less efficient i believe, anyone know the exact #s???????
ok, thanks guys, i'm gunna use a different mani then. i dont wanna shave anything, especially the motor mount, if i plan on making big power that would make it easier to break it. thanks agian
daniel
daniel
u guys think a t3/t04e with the specs below will support a h22a with good power? what kinda power u all think i could make with this and about when should it spool with a 8.4 cr?
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.82 A/R HOUSING
STAGE 3 WHEEL
thanks
daniel
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.82 A/R HOUSING
STAGE 3 WHEEL
thanks
daniel
TurboJesse
Mar 24, 2003 07:27 PM
JalopySiR
Feb 7, 2003 06:48 PM
