Sizes of the 60-1
Old Nov 21, 2002 | 06:36 PM
B20bTurbo's Avatar
Default Sizes of the 60-1
What makes a 60-1 a t4 60-1? I have seen people with t3/60-1 with .62 ar turbine and .82 turbine. Does the .82 on the turbine side make it a t4 60-1? Or is there something else that makes it different? Does the compressor side get bigger than .70? Im getting a little confused seeing different people's setups.
Old Nov 21, 2002 | 07:06 PM
fastludeh22's Avatar
Default Re: Sizes of the 60-1 (B16aTurbo)
i just got a 60-1, it is 82 a/r, w/ 70 a/r compressor...it says to4s on the box...sorry i cant help you more, i new to this as well
Old Nov 21, 2002 | 07:46 PM
PeakBoost's Avatar
B*A*N*N*E*D
the t3/60-1 is actually (i hate saying this) a "hybrid" basically using a t3 turbine wheel and t3 turbine housing on a t4 center section with the to4s compressor.
the t4/60-1 uses the t4 turbine housing and t4 turbine wheels.
Old Nov 22, 2002 | 02:44 AM
NOSed_b18b's Avatar
Default Re: Sizes of the 60-1 (CHEAPTURBOdotCOM)
What's the differences between a t4 turbine wheel and a t3 turbine wheel??? Basically what I'm asking is what makes a t4 a t4 and a t3 a t3???
Old Nov 22, 2002 | 03:39 PM
rocket_R's Avatar
Default Re: Sizes of the 60-1 (NOSed_b18b)
between the two, which one would you recommend for a built b18b? which one will make more hp and can i use a drag3 manifoil?
mrx
Sep 3, 2005 11:27 AM
B18c1turboedEK
Nov 24, 2004 10:56 PM
Kp_VtekNiks
Jul 30, 2003 12:26 PM
TurboJesse
Mar 24, 2003 07:27 PM
